Ok folks, I keep reading...and reading...and reading and I just cannot bring myself to make a decision on which way to go. I know there are going to be a lot of people who say its a personal decision, but there must be some huge benefits of going one way or another. What I just dont see anywhere is a competitive matrix and that is exactly what is needed. I know Hellroaring is good, I know National Luna is good and if you believe the marketing speak, PowerGate is the best thing since the transfer case. What I am hoping for is, "This is better because..."
Here is what I need out of my dual battery system:
• My wife can drive it and I dont have to worry about her getting stranded.
• The system needs to be as automatic as possible.
• Flicking a switch here or there is totally fine so long as everything is done from the cab.
• Installation is not an issue. Being stock there is a blank slate and I am willing to go through the pains of installing any of them.
• I will be getting two of the exact same Odyssey ala Sears batteries.
• I plan on getting a third Odyssey motorcycle battery to install in the space in front of main battery. The one that 450 DUDE set up: https://forum.ih8mud.com/80-series-tech/201721-single-tray-dual-battery-install.html
• A battery monitor is way cool BUT I can get other dual battery monitors from Xantrex (Link 20) if need be.
• I will be installing a fixed jumper cable system using Wrangler's battery to grill jumper cable kit: Wrangler NW - Jumper Cable Kit, 16ft, 2 gauge
• Engel fridge is way in the future as is a winch.
• Need to make sure any system can easily jumped in case of failure
• Unsure whether its better to run off main and use backup as a backup or use main for starting and vehicle functions and just use spare for accessories. I am open to anything at this point.
• The Toyota necessities NEED to be protected.
What worries me:
• Hellroaring, the busses are really close to each other and people seem to be always trimming the lugs.
• PowerGate, seems overly simple which means there is less options available. Haven't seen enough installs on MUD.
• National Luna, the solenoid worries me a little and I plan on running 0/2 cable so the cable in the kit is spare parts for me.
About the truck:
97 LX which is currently stock. I will be adding a 150A alternator using Photoman's bracket which I already received. I will eventually be adding a roof rack and a sliding solar panel (complete write up in the works). There is an inverter in the plans as well once I decide what I want out of a drawer system.
What worries me:
About the truck:
