Given that I want to run an aux battery position w/ loads [lights, fridge [one day], interior 12V stuff, inverter] it looks like these two are viable options. Mike at HR sent me the install document file for the 95150 and a Wire Tips document as well. The things about the 95150 that I wonder on are the recomendation to use 8g wire between BIC and battery as a charge limiter and the note that if you have a engine on load of 40 - 50 amps, them maybe this isn't the right unit.
The small cable I just feel odd about, even though it works on paper. The real question is that this looks like running an inverter on the 95150 aux side is questionable, even though I don't plan on over a 600W unit - everything else would be a relatively low load.
This makes me think about the Surepower 3141-200 battery separator as an option. Any user comments for these two units?
