- Joined
- Mar 10, 2007
- Threads
- 62
- Messages
- 1,108
X3!!
The kit came really complete and the springs look great. I bought greaseable shackles from MAF and steel brake lines from Spector and had the front u-bolts cut at Lafayette Springs here in Lafayette, Louisiana.
I'm not following; The kit was complete, but you had to other source the shackles, brake lines, and u-bolts. Do you happen to know; will the final HC "kit" include shackles, brake lines, and u-bolts?
If it is cost-competitive, I will be looking at it with one hand on my credit card.
The kit came with ... transmission cross member drop kit. The other part that took some time was dropping the transmission and keeping the new blocks in line to run the bolts through.
Tranny drop kit?? Should be cross member drop.... dropping the cross member is to gain front drive line clearances needed on lifts 4" or more.... rear bad vibes can be corrected with diff. shims....
Why lift 4" and lower an important component 2.5" I wouldn't want my transfer case loweredWhy lift 4" and lower an important component 2.5"
Yea I was not aware this needed to be done. But I will wait to see what the pictures look like.Wow, there is no way in hell i would drop my crossmember at all. I beat the s*** out of it as it is.
Im still not seeing the point in dropping the crossmember. Maybe some pics will enlighten me.
Think driveline angles. Drop crossmember: decreases the angles on the driveshaft.
Ya i understand the theory behind it, but what i dont see is why if you have the springs apart you wouldnt add a shim, rather than drop your vulnerable drivetrain even lower than it already is.
Ive got in the neighborhood of 3 inches of lift and my driveline angles are very modest.
