This one is interesting, something to go along with my already kooky experience with this setup.
If anyone recalls, back in Jan. I believe, I was having HEI problems. That got solved, and it's been running great. Then about a month ago, after the 55 had been parked in my front yard for a couple of weeks, I went to start it, and all it did was crank - no fire. I checked all the connections with my tester, and came to the conclusion that there was no spark coming from the coil. Figured it was either that or the module. Tried a new coil, but still no fire. Exchanged the coil for a module, installed and it fired up. There was another issue with that, but it's beside the point (I hope....[somehow the distributor had moved itself ~20 retarded!!?]) It ran great for a week, then, when getting ready to leave our camp for the w/e, way the hell away from town, it does this thing again! Crank, no fire. After making a phone call and assuming the module was the culprit, I checked the electrical connectors with my test light to see if they all checked out. They did. Then I decided to just remove it and then reintall it, with the idea that perhaps it may "reset" itself. After doing this, it fired up and ran great all the way to town. Then after shutting it off at the gas station, I tried to restart when done, and the same thing happened. This time I just removed the connectors from both sides, then reconnected. It fired off and I drove home.
Each time when I checked the connections with my test light, when looking at the diz from above, the two prongs on the right are hot, the one on the lower left is ground, and the one on the upper left is the one that is open or whatever and has to do with the pulse from the pickup coil. Is this right? There is also a balast resistor in the diz from the factory. Anyone got any idea WTF this could be?
