heavy duty tie rods
Medford, Oregon
I'm in the process of replacing the crappy power steering that is currently on my fj40 with a new setup. I want to replace the tierods ends and tie rods that the PO welded some funky reinforcments on. Can any one tell me where I can get "heavy duty" tierods and ends. I've seen them somewhere before but can't find them now. Thanks for your help.
I got mine from Man-A-Fre. Don't know if they are any better or not than the Budbuilt ones (Budbuilt makes good stuff though) but I like mine. Got the tie rods, tie-rod ends as a kit. Don't spend the money on the poly boots, not worth it IMHO.
Enjoy
I got mine from MAF as well.
One consideration, though: if you run a steering stabilizer on the tie rod rather than the stock location, you WILL need a new bracket and U-bolts to fit the thicker tie rod, PIA to find a supplier for that. I got mine from Skyjacker ($$$) and had to hunt several autoparts stores for the U-bolts :frown:
I ran the OME stabilizer in the stock location. Works pretty good... and it's YELLOW :grinpimp:
Hi All:
"Secret Agent," what power steering are you using on your TLC?
When I did the Saginaw PS swap on my FJ40 a few years ago I bought the custom relay rod from BTB Enterprises that is threaded metric on one end, and English on the other end. I sleeved it with some tubing that fit snugly, and had a friend weld it in place.
I bought my GM TRE at "Shuck's Auto Parts" (aka Checkers, etc.) PM me if you would like the part number.
Good luck!
Alan
