heater return line.
I bought my first FJ40. It is a 1971. It has been sitting outside under a tarp since 1997. 1997 was the last time the engine had been turned over. I must say that I was impressed because with fresh gas, new plugs, wires, and some fresh oil, the thing fired right up and it idles smooth. My problem is that I can't run it too long because I have a heater hose that has been disconnected and I can not find out where it goes. It is a return line and runs along the passenger side of the engine. It comes out of a housing that is hooked to the firewall. I took a picture. I looks like it should hook into the block somewhere so it can recycle itself but I just don't see a place for it. In the picture it is the hose that is underneath the radiator hose. Any help would be great.
The heater hose tees into the lower rad hose. You should have a two-piece rad hose with a metal tee in the middle.
See #8 in the parts diagram.
That makes sense. When I bought the FJ someone had always replaced the radiator hose. Is that a hose they still make or would I have to customize it? Thanks again for the info!
You can probably buy one used from someone here on mud and you can most definitely find them used through vendors like SOR or cruiserparts.net.
Sorry for the fuzzy picture. But in the bottom right you can just make out the metal piece that connects the two large radiator hoses with the heater hose. The radiator hoses are definitely available. The metal part may be more difficult to source. I would check the classified section for someone parting out their rig.
Seems like I also so that they were still available new in the "ultimate land cruiser parts still available" thread....
Confirmed.... Toyota PN 16577-61040
Napa also had the correct radiator hoses and heater hoses as late as two years ago (last I checked)
I did call NAPA today and they do have the radiator hoses. 15.00 for the upper section and 12.00 for the other section. They do not however carry the T section that ties in the hoses. I did pick some tubing up and I am going to just customize one. Thanks again for all the help.
