heater less effective at altitude
SF Bay Area
in the midst of summer... a heater thread!
I'm wondering if anyone has experienced this or knows what the cause could be.
When I bought my '97 with 155k a few months back, the heater was pretty weak. I flushed the core and replaced the thermostat with an OEM unit and it's been a lot better.
Last weekend I drove up to Lake Tahoe which is 5,000+ ft and I went to use my heater one morning and it was lukewarm at best.
Drove back down to sea level and it was back to nice and hot.
Does anyone know how altitude could be affecting my heater? I'm scratching my head here. Air bubbles perhaps?
If it helps at all, I'm in the process of modding my fan clutch due to some mild overheating issues.
Thanks!
My guess is it was some other factor. Mine works fine at any altitude up to 10k.
Check the heater control valve in the engine compartment on the firewall (almost in the center) There is a cable you can adjust so the valve will almost (there will be a small gap IIRC) be closed. No issue at alt here.
I thought that as well, but this isn't the first time it has happened strangely enough.
I'm not totally sure what you mean. My Heater valve is new and seems to open and close properly according to where my heat slider is.
Well, the air is much thinner at altitude. Therefore, since your heater fan is turning a fixed RPM at either altitude, it will move less MASS of air at altitude than at sea level.
When we design blower packages to convey dry granular products, we have to increase the electric motor size as we increase elevation due to lack of cooling. The fan on an electric motor has insufficient cooling capabilities at significant elevation (I believe it's 3300'+) We also have to increase the speed of the blower to get the correct MASS of air to move the product. At 5K ft, the air pressure is about 17% less than at sea level, so you will be moving 17% less air mass.
Water boils at a lower temperature at elevation also because the atmospheric pressure is lower.
It's all referred to as psychrometrics.
But he's talking 5k', I regularly go above in dead of winter to ski and my heater melts my feet.
I don't disagree.
If his heater is already marginal or partially clogged for airflow, then the effect would be magnified at altitude. He may not notice the problem at "home", but when he goes up higher, it becomes obvious. Not to mention the fact that the temperature typically drops as you go up in elevation, so there has to be more heat transfer, with even less air mass.
He was asking about "why?" That's a "why."
Now he should look into: What do I need to fix that's not broken, or at least what do I need to fix that the collective on 'Mud has convinced me is broken, and therefore, I must pony up lots of extra cash to fix that which I am perceived to be broken. I cannot have that.
You need a new bumper, maybe some cupholders, and a lift. Oh...and do your PHH while you're there because you're about to invest in the following:
New radiator
New Belts
New water pump
New cooling fan hub
Radiator / cooling system flush
New thermostat with gaskets
And bypass the metal rear heater lines when you do all this.
Just because. FIx it until it's broken.
Makes no sense to me. Hot air rises, so it should work better at high altitude?! :meh: :hillbilly:
True! But, water always runs downhill, so at higher altitudes you will only get less waterflow to the heater?
But, if you put a sail on the roof and a fan behind it, what kind of gas mileage will you get?
Check your heater fan for debris. As @BILT4ME mentioned the air is less dense the higher you go so at a fixed fan speed it will blow less air mass across the heater core.
I'm in the same boat as @retrofive, I regularly drive above that elevation in the winter and can cook my feet to medium rare when the heat is on.
