Was driving the FJ40 tonight, about 50mph when my headlights decided to shut off, it seemed to happen when I was switching from low beam to hi beam, I am using a floor mounted switch for the high beams, I am also using a headlight relay kit that I purchased awhile back for the stock headlights, basically it uses the stock fj40 wiring but uses relays from the stock to the headlights with new connectors on the headlights, it is all Hella products. I was thinking a possible bad relay but I would think this would only cause a dimmer headlight, due to the fact that the relay should be increasing the output to the headlight. I looked for bad wires and there were none. Will check the fuses tommorrow. I can't remember what new headlamps looks like but I checked mine and they have some darkness at the front of the bulb, not sure if this is normal or means that the are blown.
Just curious if anyone can point me in the right direction here? It seems weird that both lights would blow at the same time? Is it normal for one to blow and to cause the other to blow? If the hi beam relay crapped out on me would that cause both headlights to blow?
thanks for any help.
Noah
Noah
I seem to recall that the problem was a failed headlight switch.
