I have referral who can cut your complete pattern an another shop who can bend it up off jig. The expensive part is the mold an plastic around light to fill space. Unless you did a solid. Don't do that do a illumination housing. I would Make sure everything is adjustable to fit each other needs. I'm busy but watching. Let me know in in Phoenix I'm throw you there numbers. I sport your lamps boss man if there clean I Digg wat I see.
Thanks for the input.
I'm actually in the process of building an entire grill / headlamp combo.
I have the headlamp buckets adjustable. Then the headlamp brackets are adjustable as well.
I designed it this way so that, the headlights can be adjusted with the actual buckets, then fine tuned with the brackets. This will address any issues with bent core supports, or different grills.
I've been fabricating with steel, but about to do the final build in aluminum ( I hope it holds up).
I was originally going to use the factory grill and build around it, then I tinkered with the thought of using an FJ Cruiser grill, now i've decided to build something original.
I'm also in the process of wiring an auxiliary fusebox. My GF bought me a backup camera w/ mirror ( I had to 3d print a mount for it), and I'm installing a Raspberry Pi 3 (to control all my auxiliary lighting, radio, nav, and anything else i can program for it to do.)
I do have some rock lights sitting on the shelf, and I cant think of a good place to mount them.
If anyone has any recommendations, I'd appreciate it.
