- Joined
- Jun 3, 2014
- Threads
- 16
- Messages
- 163
I installed the Toyota headlight kit (81110-60P70) and I've got a problem (well, two). When I turn the headlights on, the high beams are the default. When I push the turn signal stalk forward (to activate the high beams), it reverts to low beams. So what's going on? The terminals are connected directly to the battery. I've connected the male connector (A) to the passenger side female connector. I did have to replace the ring terminals so that I could connect them to the battery. That shouldn't matter should it?
The other problem was something that is evidently common; the high beam indicator doesn't come on. I'm planning on picking up a LED bulb for that issue.
See below for photos. The first is with the low beam indicator off. The second one is with the high beam indicator in the on position.
