Is there a walkthrough for this? I've looked all over for a couple hours and I can't find anything that walks you through this procedure. I don't have my owner's manual and I can't believe I've been unable to find this stupid simple procedure.
wanted to reopen this old thread. I have a 91 cruiser. I have my DS headlight bulb out. This thread implies that the battery is on the DS, but my cruiser it is not. I'm trying to figure out if it can be done by feel, or there seems to be a few things (hoses)in the way to get to the bulb connector. Sorry about the newbie type question. I have searched a bit, but no luck. It looks like the PS is easier, once the reservoir comes out. This thread was one of the better comments on the topic.
Without the battery there it is probably easier actually. Mine is still in the stock location, but you can do it pretty easily, (I am assuming 91 is similar to my 96). Anyway, I just found it easier to loosen/turn from the top by gently tapping a long flathead around the edge of the housing. Then I could easily turn it all the way and pull it out from behind.
What's the issue here?
The bulb rotates about 1/8th of a turn counterclockwise to release it from the housing. Pull the bulb out of the housing and disconnect the connector. Attach the connector to the new bulb being careful to not touch the glass of the new bulb. Put it back in. Honestly, there's no magic here. It's a light bulb.
Awesome thank you -- 9011 sounds like the way to go and glad to hear the color is standard and not blue!@jatree
You don't want to use LED bulbs in standard housings.
The common "upgrade" with stock housings is using wagner 9011 (high) and 9012 (low) HIR bulbs instead of the standard 9005 and 9006. You have to trim one of the tabs just a little bit, but that's easy. It's not a huge difference, but a bit brighter than a stock bulb, and the color is standard, not leaning blue.
Some people use the 9011 highbeam bulb in the low position for another little boost in light output. I believe you have to add the o-ring from the original bulb for it to seal, as the sizing is slightly different between low & high. They don't last as long, but if you are looking for more light in a stock housing, that's a way to do it
