Headlight auto-on sensor hack
Super77
Seattle
I've never been quite happy with the auto headlight setting. It activates later than it should, when it's well into dusk. My other cars activate much sooner, so I've been trying to tweak my LC's sensor to do the same.
AFAIK from reading here, there is no electronic adjustment to the circuit. So I've been working on the photocell itself, located on the (US) passenger side of the upper dash. I started with layers of yellow Post-its over the sensor, just to confirm that by shading the photocell, the auto headlights activate sooner. This works, and the opacity requires equals about 2 Post-its (with no light creeping from the sides).
Next, I wanted to modify it in a way that was non-destructive, fully reversible, and stock-looking. The solution was "sunglasses" for the photocell in the form of a plastic blister taken from watch battery packaging, and painted on the inside. The blister has a brim around its outside that works well to lightly glue it down around the photocell.
It works (kinda) but the paint is hard to control and too opaque. I used a q-tip to wipe away enough paint to let just enough light through, but this leaves an opaque disk in the middle that casts a shadow on the sensor. Not ideal. I need a consistent translucent layer, tunable, ideally matching the dash color. The goal is to look like it came from the factory this way. Anyone tried something similar that works well?
I believe on early 100's, you just twist the sensor to adjust sensitivity. It'll probably look more stock that way too. :rofl:
Mine does not twist. Also tried prying out the assembly with a trim removal tool, but would not pop out.
Weird. Mine does not look like in the illustration. It's not integrated into the defroster vent - it is on its own little panel to the right of the vent, and the photocell does not appear to turn. But...
My MY99 FSM confirms same. Is there a trick to getting that sensor to turn?
That may not be an accurate illustration but that is a Land Cruiser 100 manual. Maybe yours is jammed from never being moved for 25 years. Read below...
Try marking it with a piece of tape (to mark position) and then taking two pencil erasers to twist? I'm not trying on mine... it's calibrated fine as it is.
So anyway, I got this stupid thing in my hand after prying it out of the dash. The little dome twists and is various thickness so when you turn it, it allows more or less light through to the sensor. And no, I'm not taking a picture of it.
I didn't even realise auto headlights were an option - very cool.
If the turning option described above doesn't work and you revert back to your original idea, you should look at gel lighting sheets, they aren't actually gel to the touch, they are large sections put over lamps, flash units etc to project a particular colour in photo studios etc.
In addition to them being available in numerous colours, you can get different levels of transparency, meaning you could dial in the amount of layers needed.
I appreciate this still wouldn't be ideal, but worth considering over post it notes :)
Ha! The '2-pencil' trick worked to turn it :bounce:. So yes, can confirm that 99 is per the FSM - just looks a little different from the illustration.
90 deg CCW, we'll see this evening if it makes a difference. Anyone know what the full range of rotation is?
I did not know that the sensor was adjustable let alone rotate. Interesting to know. I might need to go over the owners manual, it has been a while.
I learned something today. And love the Rube Goldberg approach to what ended up being a stock feature 🤣
Quick follow-up: turning the photocell max CCW seemed to make a little difference, but not quite enough. I basically want daytime running lights in all but full sunshine, so I'm experimenting with a combination of the built-in adjustment plus some kind of shade over the sensor. Will post back here with any updates.
You got any old freebie eye dilation roll lenses?
Eclipse glasses?
Do we have a "Features that most people don't know about" type thread? This would certainly qualify.
So I tried mine and it seems stuck too. What's the trick to removing the panel without breaking anything?
Did the “2 pencil eraser” trick above not work?
It took a bit, but I finally got it to move. I tried it both directions to free it, so now I'm not sure how it is oriented compared to how it started! 😂
Here is how it is now, and I don't think it wants to go any further to CCW.
The photo is oriented from the passenger side. Front of car is to the right.
Got a photo?
Sorry... apparently I failed to attach that to last post.
