Header coating?
I used the generic hightemp paint from NAPA (I thoroughly cleaned up the header before spraying), that sh!t is useless, I'd bite the bullet and get it ceramic coated. That said, I used POR high-temp paint on the engine block of my FJ40 and it is holding well, under those kinds of temps.
BBQ grille paint holds up for a while. Follow the directions, and you' should be okay. Can be purchased at most local Home Depot/Lowes, etc....
FWIW I have heard alot of good about the high temp stuff from POR15, but I have no direct experience with their high temp product.
Edited because I kain't spail!
Yep ... paint used for wood stoves. Also be sure timing is not too retarded beforehand, otherwise pipes will cook it off.
Rice
Idk about the bbq stove paint suggestion. I've never had a stove that actually kept the paint on it over any long period of time. The one we've got at my house now is a really nice Weber grill and all the paint has come off the inside of that thing... I'd said powder coat or ceramic. PC would probably be cheaper.
I put high temp paint on mine, after a thorough cleaning...started peeling right off in some places. Think I'll powder coat when I next pull them off.
I did the ceramic coating from a place I found on the internet, not sure what the f they did but I got rust within weeks, I think the bitches just spray painted them and took my left nut. I would not trust ceramic coating again without a few rec's from people whom have used the shop.
Noah
I had mine coated locally (Performance Coatings) & yeah it was spendy but I won't ever have to worry about the rust demons attacking it - sandblasted & coated inner & outer. I thought it'd be a thick coating to help with underhood temps, don't believe that. It's just to prevent rust.......
Noah
The shop is the same one that did the coating on Nolan and Gary's buggies ... and all the work for Sunray Engineering, so I'm not worried about that. Guess it's the best option?
Tucker
tucker74 said:
Can you powder coat them? I would think it would soften with the heat since it's essentially a baked on product? Do some types have higher temp ratings?
Tucker
I had a brain spasm. It's ceramic not powder.
I bought a cheap used header while in Alaska. I paid $30 for it. I sent it to Jet-Hot for coating. Within a year it started showing surface rust. I moved before I could do anything about it. Once I got settled in I took pix and sent them to Jet-Hot. They had me send it back for recoating for free, but I had to pay for shipping. They state they have a lifetime warranty on their coating, but it's a bit weak. They etch a customer # on the inside of a flange, and if it has been recoated they modify the #. They will only recoat one time at their expense. I had my issue a few years ago, and the second coat is showing no signs of rusting again though.
Send it back to MAF, pay the extra ten bucks and order the chrome one. I went through two of the MAF 6 - 1 headers in the eighties, having each sandblasted and hi temp painted. Lasted maybe a year to 18 months. Finally bought a chrome one, just for the hell of it. It has been on the truck since the late Eighties. Chrome doesn't look so good anymore but no rust, no leaks.
Media blasted mine and then coated with POR-20. No problems so far.
Do you have any miles on that thing! Looks really good. I am going to help make a set of headers for a 4.3 v6 in a mini truck soon, and looking for coating options for that as well.
I have a downey header on mine, chrome plated. It doesn't look too much like chrome anymore, but it's not rusty and it's been on there for I think 3 years.
I used the POR-20 on my rams horn manifolds. So far,(2 years) is holding up well. A few flaking areas now showing, but mostly intact.
