Head Light wire question
Hot Springs
Well I took time to trace down the problem of no headlights, but all other lights work with the exception of turn signals, i made a jumper wire to go from the fuse pannel to the headlight switch after locating the correct pin I have one head light that works, when i plug the harness back in I loose the one light, so I pulled a spare switch and installed and nothing, is the plug bad or is there something I am overlooking, surely I dont have two bad headlight switches?
thanks
Did you check the lights themselves to see if they work? Jump +12V to the lights. This will tell you if the lights are good and they have a proper ground connection. Then trace backwards from the lights looking for problems.
What year model?? and don't forget to check the dimmer switch..
Ok I have removed the plastic cover on the headlight switch, and no power, on the pin, but I can jump power to it and make it work, is there a source for the harness plug, or will I need to fab something, I really want it back like it should be, by the way its a 74 FJ40, and I still havent figured out the blinkers yet.
IIRC..a red wire is the feed.. from the bottom fuse..
Sounds like corrosion/dirt in the internal contacts, same problem I had. I finally faced the reality of having a 32 year old light switch that may die on a dark road while driving...bit down and spent the $$$ for a new one. Some things I just can't skimp on.
