*!^#*&^($!*&#^ Head gasket!!
Turbo,
No worries, and you're kind to say so. Also, I think I mentioned it either in the DVD or the posts on the subject but I looked into buying a head flatness checker so I could check myself but it was very expensive due to the length of our 1FZ heads. I think it had to be 29" long which was quite long in the 'head flatness checking tool' world. Not worth doing it yourself.
Ballistic - yeah there are a couple things to so so easy and cheap it would be folly to ignore. Example: I think the alternator brushes cost about $11 and took 4 minutes to install. Normally, it would be several hours to get the alternator in/out (battery tray, etc) if later its output dropped.
DougM
Enrique, I will check the cash flow worksheet at home... but all the knowledge that I was able to obtain from Joe and his father, priceless... and I'm still learning with every single visit to his "shop"...
the head job was like $600-700
the injectors cleanings was like $100-200
spare parts, no more than $3000 for sure... but I did several orders to Cruiser Dan...
Buttercup is running great, I have a TO DO list for more stuff, but none critical...
? What about milling the head enough to get a little bump in compression?
It's already 9:1. Cut too much and you will need to address cam timing.
As Dan says. If someone produced a adjustable timing gear then you could reset the factory cam timing back to stock.
As for legal, it is just not to Toyota's specs that could mean a difference in possiable emissions. As for what people have gotten away with in milling the head. I usually have the heads cut up to .010, I have had to have one cut to .012 for flatness(not really enough to heat flatten according to the machinest I use). Any how I have done more but have returned the machanical cam timing to stock by adjusting the timing guide at the time of a full rebuild.
The more I do these head gasket jobs, the more I see the need to at least surface out some of the pitting that I see from coolant not being changed and creating electrolsis(can not spell worth beans tonight).
One day I may have a post count near Dan's(in my dreams).
Also, make sure that if you have the valves ground that the machine shop tips the valves to get your valve clearance back into spec. I didn't do this and spent a lot of time waiting for new shims, some of which are made of unobtanium. I still have one ticking valve because I got tired of waiting for the last shim I needed.
Let me clarify that statement: make sure that when the machine shop does a "valve grind', they also trim the ends of the valve stem the same amount. :D Otherwise, your valve stems will be a tad too tall and you'll need to shim up the cam shafts accordingly. These bucket shims will need to be ordered and take some time to setup.
:D
If the machine shop has done these style of head before, they should ask if you want them to adjust the valves for you. Say yes and pay the price, it is far easier for them to set the valve lash then you trying to get it right the first time and to order the shims.
I asked my machine shop to adjust the valve clearances and offeed them the camshafts and all hardware. Their answer was that they don't adjust valve clearances, assuming that's what we're talking about, w/o having the head on top of the block. They are of the opinion that the torque placed on the camshaft bolts can "tweak" the alum head. Just my experiences FWIW.
I did everything I could once the head was off. I had a lot of things to repair and it made sense to do them all at once.
head checked, and machined
adjusted valve shims
replaced valve seals
valves cut
replaced ALL heater hoses & PHH
replaced water pump
replaced rotted radiator
replaced alternator brushes
replaced oil pump seal
replaced front crank seal
replaced timing chain slipper (I had the old defective one)
replaced fan clutch ( be sure to modify it. its a POS otherwise)
resealed timing chain cover and both oil pans due to leaks
cleaned intake plenum and installed PCV catch can
cleaned throttle body
sent injectors to RC engineering
rebuilt leaking PS pump
Thats all I can think of now. Make sure you use OEM parts and follow the FSM you don't want to revisit these repairs. The engine runs great now much more power, and not one drop of oil anywhere!
Not to hijak the thread but I'm picking up alot info on this topic and curious about alia176 posts re: grinding valve stem tips.
What have been others experience with machine shops doing the adjustment as part of the valve grind?
Our service department routinely sends heads out to the machine shop along with the cams, shims and buckets. It costs more but on the other hand 24 new shims at 8 bucks a rattle is not cheap either.
When valves and seats are ground the stem of the valve moves upward and if nothing else was done all the valves would be "tight" and they will burn. If the shop "tops" the stems of the valves the same ammount as the valve margins and seats were changed then the same shims can be retained.
Wow! That was a big project.
-B-
That it was. It took about 5 weeks to get it back on the road I also sand blasted all of the rust around the battery tray, and around the radiator and repainted. It was summer so I wasn't into working on it every day the other holdup was that the more you dig into it the more parts you find you need to order and parts from Dan take about 7-10 to get to NJ longer if he needs to order them from LA or Japan. I glad I did it myself I know it was done right and it was a great learning experience.
