Lcer's
I have a 72 (Mnf 71) with a replacement block (it has been determined in multiple threads). I ordered a head gasket for a 72 (a 2F engine and I compared it with the head and block before installing.
It appears to be missing a cut out in the gasket. Two pictures are attached: One shows the location of the port in the engine block (and has a corresponding hole in the head). The other shows the gasket and where the hole should be.
My question: Is this a water port? I can smoothly cut a hole in the gasket and correctly seal it, not an issue. But is this "non-hole" by design? I do not believe so. Thanks. It is in the front driver side of the motor.
Boaf
Boaf
