Y'all scared me so much with head gasket stories, that I bought a 'practice Toyota' for head gasket fun. I have a '95 FZJ that was weeping outside the block before bought it at 75K, but has never shown signs of a blown gasket. It currently has 157K. The crusty-residue on the block has never gotten worse.
So - behold - an '87 Camry, 3SFE engine, 2.0l, DOHC, with 212K miles, a freshly blown headgasket, on Craigslist. $225 takes it home. My plan was to learn how to do a head gasket, and pick up an econo-beater car in the process.
Being a Colorado car, it's rust-free and worth fixing, sorta.
Following much advice on this forum, I did a compression test, then pulled the head. The gasket was blown on the #3 cyl and showed 95 psi. Water shot out of the radiator cap when I compression tested #3. Other cyls showed 135 or so. When I pulled the head, the head bolts near the #3 and #4 cyl were not near as tight as the other 8 bolts - can't say why. The old style bolts were a 'tighten to 57 lb-ft' design, and the replacement Toyota head gasket came with new TTY bolts that are a 'tighten to 36 lb-ft, then turn an additional 90 degrees' design.
The alloy head surface was flat within .0035, spec is .002 - I decided to slap it back on there anyway. I didn't check the block for flatness. I did replace all the valve stem seals with a home-made tool, and replaced one valve shim. I found a quart of 20w-50 in the trunk and I suspect the PO was using this oil to slow down oil burning. The oil in the crankcase was fairly thick and sludgy, but not mixed with water.
I got the full disassembly treatment, including pulling all the wiring harness out through the firewall and across the top of the engine and fiddling with the fragile cams. As far as the work, this engine has a LOT in common with an FZJ.
After several full heat cycles and some light flogging, the compression is as now: 133, 133, 132, 133 on my Craftsman gauge. Can't complain about that. The cylinder bores looked good in the engine, and carbon build up was minimal.
The engine runs very smoothly and quietly. I have about $350 into the car at this point.
Things I learned:
Check the valve adjustment before you ever take the head off - then you can get the shims you need while it's all apart for valve stem seals.
Buy a Toyota head gasket - this one came with 10 new head bolts and washers, and was $49 - same as Fel-Pro. I'm 99% certain the aftermarket gaskets don't come with new head bolts.
Don't be afraid to dive into something like this - I've never touched a DOHC engine with a timing belt and while it was involved, it wasn't really hard. I feel much better prepared to do the job on my FZJ, now.
Now, back to your regularly schedule FZJ stuff in this forum.
Steve
Things I learned:
Steve
