Head Gasket FollowUp (or, how I spent my summer vacation)
McCall, ID
For those of you who recall my blown head gasket story from earlier this summer, I thought I'd let you know how things have come out, and take time again to thank all of you who had good and helpful suggestions.
To briefly recap, hot day, pulling dory boat on trailer, HG on my later F blew. Limped part way back on river water. Stopped again and hydrolocked and had to be towed the rest of the way home to be safe. (Learned about hydrolock. :D )
What happened was the HG had burned through at the edge of #6 cylinder, it appears because there was so much sediment (4 inches deep) in the waterjacket at the rear of the engine around #6 cylinder. This stuff was so nasty that it took HOURs digging with screwdrivers from above and below to clear it, so that the drain on the engine block was open. I have looked at 2 more engines of my own, and am aware of several others (all F and 2F, early and late) which have the same problem to one degree or another.
I took the $200 opportunity (head off) to have valve seals replaced, valves ground (little needed) and asked to have the head shaved 20/1000ths. Machinist nicked the head taking it off the machine, so he had to take off another 10/1000ths. Oh, well.
So, after learning that non-OEM head gaskets easily fall apart, I got everything back together, the water jacket cleaned out, and readjusted the valve lashes (which changed because of the head shaving). Also, ran some Seafoam through just for grins.
Now, what I have found since is interesting. I had done compression checks the month before this happened, and the numbers were fair: 127 in 3 cylinders, 140 in the other 3 (150 is standard for F engine). Adding oil to the cylinders corrected to 146-148 on all cylinders, which would indicate some ring leakage, right?
So, after the head shaving and valve seal work, the compression on all 6 cylinders is 168-170! Same as is standard for 2F engine. No, didn't bother adding oil to the cylinders. Guessing my rings were all right all along.
Definitely more "seat-of-the-pants" oomph, and, objectively, I can go up a test hill near my home at 55 mph, which it was all I could do to go up at 45 mph before. And, fuel efficiency up from 17 mpg to 18.5 under same conditions. :D
So, in all, a not too expensive, actually, upgrade to my system! Thanks again to everyone for the direction! (Yes, Mark, I know you said don't shave the head, but there you are.)
Keep an eye on your temps now.
But honestly, more compression is one of the easiest way to get "free" power out of a cruiser motor.
It does not rob low end for more high end.
Head shaving on the second rebuild of the F155 in my 68 resulted in 180 pounds of compression, an off road temp of 190 and a strict diet of premium gas until the compression came back down. Yah it was wheelie-poppin fun for a little while, but now I'm more interested in longevity, so there you are.
Why the premium gas, Mark? I assume you had preignition and pinging. I'm not having any pinging with my setup. Did it change the cylinder dynamics for your system in some way?
Glad it all worked out Dave. 18.5MPG, I only get 14 MPG. I wish I knew hoe to get the MPG you do.
Ken
Dunno, Ken. I drive (nature of the roads) a lot of those miles at 35 - 45 mph. And I have the high elevation jets. Lots of little things got me there from 14 mpg.
IDave about the premium thing....
Because he's got a LOT more compression than before, the fuel/air in the cylinder heats up a lot quicker and causes that pinging...running a better gas stops the pinging
Geoff
