90 HDJ81 with factory winch. What are the factors that may reduce the pull strength of a factory winch? I went to use it for the first time and found it’s pull no what I would expect from this winch. I’ve used other winches so I have a feel for winch strength and this one seems to stall far too soon in the pull. I’ve had this winch off the truck, apart and reassembled. It has a new 5/16 wire rope, new fluid. I had my idle up in the truck too thinking it wasn’t getting the power. I’m going to need a 2nd snatch block if I can’t get it pulling better. I’ve heard it’s possible rated at 9500#, definitely at least 8000#
Thoughts?
Another questions. Are there any aftermarket winches that can fit as an OEM replacement?
Thanks.
Thoughts?
Thanks.
