HDJ81 Starting Issue (SOLVED!!!)
VCT Circuits waits for +12V across 4&7, then
One other question, where is the +12VDC input signal for this coming from for pin #4?
Disregard. I got the schematic out. But I’m wondering if this fusible link had blown I wouldn’t get the +12VDC signal from the VCR to the VCT therefore maybe that’s why the ground signal is not triggering?
I’ll check tomorrow.
I now have a correctly starting Land Cruiser. The +12VDC signal to the VCT was not occurring to pull in the starter relay.
And that would be because I incorrectly installed it on the “E” post of the VCR and not on the +1 post. So my month of troubleshooting was all self caused. On the bright side I am now infinitely more knowledgeable about my HDJ than I ever was.
:cheers: Major thanks to gte343z :clap: for his excellent troubleshooting information, 1 little spark got me realigned and on track.:beer:
Ahhhh! That's the worst! Chasing ghosts, then realising you set the ghost loose yourself!
At least you got it sorted.
I’m having this same no start issue. When I turn the key I hear several relay clicks but no start. It will start if I jump pin 7 & 3 on the VCT. Before trying source a new VCT what are the reasons the VCT wouldn’t receive a signal to start?
+12VDC is provided to the VCT by pin “E” on the combining relay. Have you checked voltages there?
I’m getting about 1.6V at the “E” post on the VCR. Also, a new symptom, the VCR is now “buzzing”. The contacts keep rapidly switching I think.
Just posting an update here just in case it helps someone. My cruiser starts as it should. My problem was the battery terminals. They were so worn out that when they were "tight" they still weren't properly tight so the system wasn't getting the voltage it needed. Thanks for all the information posted here, it may not have been related to my issue but like IDZens has posted before, I feel infinitely more knowledgeable about the starting system on the truck. :cheers:
The best is to delete that 12/24v conversion relay and throw in a 3kw or 3.5kw starter
Hi all, piggybacking on this thread as I'm having many of the same issues.
I was driving my HDJ81 and noticed-while still driving-that all the gauges except the fuel gauge and speedometer stopped working. Radio was still working, truck's clock as well, blinkers etc all were still working. The windows did not work. When I turned the truck off and tried to turn it back on, nothing. No clicking, nothing. Here's what I know:
- both batteries are fine, showing 12+ volts, and all electrical I mentioned above still work (radio, headlights, etc). Turning the key turns on all accessories, but gauges don't turn on, I just get the warning light above the voltage gauge.
- I checked all fuses in the main relay box and power outlet box, and all connections I could check, all seem fine.
- Measured voltage to the starter, it was at ~12v (though didn't check when trying to turn the car on (been doing this solo so far)
- I managed to run 12v from the starter battery to the starter relay, and got the starter to click/engage, but nothing beyond that
This is as far as I've gotten, beyond reading all related threads I can find on IH8MUD and the engine/chassis manuals, but don't feel like I know how to do much beyond this, such as check for continuity at the starter relay, VCT or VTR or NSS (I don't even know where the latter 2 are or what they look like!). Given this happened while driving, and the truck drove fine after it happened, and the only thing NOT working is the ignition, I'm inclined to think its the ignition switch. But I don't feel like I know how to check this, and of course don't want to go throwing money at something without knowing the problem.
Any help would be greatly appreciated, especially since I can't find a single shop anywhere near me that's willing to even take a look...
Hey! Considering the fact that you have more electrical issues than just starting I’m thinking it’s more than just the ignition switch. I remember reading a thread with similar issues when I was troubleshooting this. They’re problem was the plug/connection underneath the windshield washer reservoir. The wires beneath had become corroded causing the no start issue as well as other problems. I’d pull the reservoir and take a look!
Hi,
Last year I had some intermittent no crank issues with my 1991 hdj81. I was convinced it was the Voltage Converter Relay at first as i was see excessive voltage drop across it after startup when the batteries where charging back up. In my case it turned out to be the NSS (if I jiggled it or put it in neutral it would start); a under the truck disassembly, clean, sand contacts and grease fixed it. Before doing that i spent some time trouble shooting the starting circuit and will give my 2 cents.
First of all, regarding your diode on the pcb. In some circuits you most remove at least one leg of the diode in order to test if it is good or not (other components in parrallel with the diode can give you a false reading with the DMM).
The VCT operation is rather simple:
Key in On Position:
---- 12V across pins 2&7
---- 0V across 5&6, 1&3, and 4&7
---- VCR state
1+ connected to 2+ (LH/RH batteries in parallel, by connecting positive terminals together)
E connected to 1- (LH starting battery neg post connected to engine ground)
Key in Start Position:
---- +12V across 1&7
---- VCT applies +12V across 5&6
---- VCR actuated
1+ & E No Connection
2+ connected to 1- (LH battery in series with RH although only the starter (and alternator charge cable if connected to LH battery) see 24V)
---- VCT Circuits waits for +12V across 4&7, then
---- VCT connects pin 7&3 grounding the E pin of the starter relay (cranking the engine if everything else is functional)
A) I would suggest first manually running the starter to make sure the VCR and starter are working properly.
1. Disconnect the VCT and VCR harness plugs
2. Apply +12V from the RH battery (drivers side of hdj81) across e and g of the VCR
3. Check for +24V at terminal 30 of starter, check voltage across 2+ and 1+ on VCR (leave DMM connected for next step)
4. Apply +24V from the 1+ terminal of the LH battery (drivers side of hdj81) to terminal 50 of starter
5. Engine should crank, during note voltage drop across 2+ and 1+. If excessive could indicate failing VCR contacts.
B) If the above process works repeat, but this time for step 4 do this (checking the wiring between starter relay and starter):
4b. Jumper across the B & MG terminals of the starter relay plug.
C) If the above process works repeat, but this time for step 4 do this (checking the starter relay itself):
4c. Apply +12V from the RH battery (drivers side of hdj81) across E and ST of the starter relay itself (while the plug with B&MG pins is left connected).
D) If the above process works repeat, but this time for step 4 do this (checking the ignition switch and wiring to/from the VCT):
4d. Jumper across pins 7 & 3. Then turn the ignition switch to start position
E) If the above process works repeat, confirm that the only issue present is the VCT not applying ground to terminal 3:
1. Reconnect the VCR and VCT plugs. Disconnect the starter relay harness plug containing the ST/E pins
2. Turn the key to/and hold in the start position
3. Check for operation of the VCR confirming +24V at terminal 30 of starter
4. Connect E pin of starter relay to ground, then jumper from harness plug ST to ST pin on the starter relay
5. Engine should crank, during which note voltage drop across 2+ and 1+
If all of the above checkout then the VCT is likely faulty, although a low voltage or bad ground to the VCT itself may cause the circuit to misbehave as well. If so, you could probe the voltages the VCT pins while performing step E. An oscilloscope and circuit model would make this much easier and definitive. If you are comfortable soldering a pcb, you can use a soldering iron to free up one leg and then test it properly (preferably with the diode test function of your DMM, rather than resistance mode). If it is bad, finding a replacement should not be too hard, but there is no guarantee that will be the only bad component (there are other solid state components present... transistors/mosfets).
Pay particular attention to the VCR making sure that it maintains 24V operation under load. The VCR takes alot of abuse in the case of having one battery low and the other fully charged.
BTW, there was recall in Japan related to the issue that you experienced to start this whole mess. Below is the info from toyota.jp when i ran a recall check for my chassis #.
1. Vehicle phenomenon
  1. (1) Repeated running such as off-road or large step ride may cause excessive force to be applied to the steering and suspension relationships, so the knuckle arm mounting part may slacken or the cross shaft of the gear box may deform. Therefore, if proper use and maintenance are not performed and the product is used for a long time as it is, the part may be damaged.
  2. (2) When starting the engine with the performance degraded of the battery, the operation of the starter circuit control computer becomes unstable due to the voltage drop, and the contacts of the electromagnetic switch repeat ON / OFF in a short time and the wear of the contact may be accelerated. As a result, it takes time to start the engine or noise is generated. If the contact of the electromagnetic switch of the starter is used as it is and the contact point of the electromagnetic switch of the starter exceeds the wear limit, the contact generates heat locally and welds and the starter May continue to spin and smoke.
2. Content of improvement
(1) In addition to informing about the use and handling of cars and the necessity of maintenance and maintenance, we will inspect the steering relationship (free) and if there is any abnormality, I will ask for maintenance.
(2) In addition to informing the maintenance of the battery and precautions at the start, inspect the electromagnetic switch of the starter (free) and replace the one with large contact wear with new one.
S-HDJ 81V KC-HDJ 81V
Toyota
Land Cruiser
HDJ 81-0000017 to HDJ 81-0078271
From January 22, 1990 to December 22, 1997
(1) (2)
Another hijack of this thread. I installed the Window Rocket kit recently, and then could not get the engine to start.
Hi,
Key in On Position:
---- VCR state
---- VCR actuated
Toyota
Land Cruiser
(1) (2)
Another hijack of this thread. I installed the Window Rocket kit from @PIP and now have starting problems.
HDJ80, 1HD-FT ,5-speed manual, LHD.
Initially plugged the Window Rocket into the wrong relay socket, mis-reading instructions. I thought I read to plug it into the top relay, but it was the top relay on a relay board assembly. I plugged into where the red arrow is shown, but it should have been where blue arrow is shown below:
I removed the Window Rocket kit to troubleshoot, but have come to a standstill with what to do next. From an 80 series Wiring Supplement document, here is the starting wiring diagram with some of my highlights.
At one point I thought the starter solenoid may have been bad. So I pulled the starter & connected 24V to the starter motor. Applied 12V to the solenoid and it operated correctly.
Reinstalled the starter. The 12-25V Switchover Relay operates correctly when the ignition switch is turned to Start, with 24V confirmed at the starter motor. So I disconnected the solenoid connector (blue highlight) and applied 12V directly from the battery - but no starting. That one puzzles me.
For the pink highlighted relay, I cannot locate this. The manual looks like it indicates that it is located on the right side kick panel, but it is not there. It may be buried up somewhere abover or around the glove compartment, but I may have not dug far enough yet.
So looking for someone that understands the system, and what specifically could be keeping it from starting. Am I overlooking something obvious? Can anyone confirm the location of the 12-24V Switchover Timer Relay? Did I dislodge or damage wiring of some sort when fitting the Window Rocket? Any feedback and guidance is appreciated.
