I checked at dealer for piping between compressor and rear element... something around 1800$, and it looks like they don't last long.
Sorry everybody for switching to french, but my english is not fluent enough to say what I want to add and I guess Eleblanc speaks french.
La tuyauterie entre le compresseur et l'évaporateur est composée de plusieurs tuyaux en alu dont l'extrémité se termine par des pièces filetées en acier.
Alu + acier +sel = corrosion galvanique, les joint sont rapidement détruit (2 hivers pour moi) et ne se détaillent pas, il faut racheter les tuyaux entier.
If you want to go that way, my advice would be to find someone able to build "one piece" pipes.
Hi Adam,Pour ceux qui ne parlent pas français![]()
May I ask, why you are installing the AHC?
I like that HDJ100 Rally-Raid trucks exhaust....maybe that, coming out both sides...is what my truck needs to be loud again?![]()
The only issue I heard about is you can't carry more than 400kg while in "high" position, wich is a major concern when you want to cross Sahara.../... Other then being subject to alot of problems, what is wrong with it when it runs fine?
Don't know about the "medium" position
