Has anyone ever seen this?
I am rebuilding the front axle, and found something interesting. Has anyone ever seen this?
The top bearing race in my drivers side knuckle is set into a sleeve that is milled into the top of the knuckle. The race sits higher off of the knuckle, so a custom 1/8" shim was used.
Everything seems to be fine. The work looks like it was professionally done, and everything was solid. I checked the brass insert in the spindle for damage, and it seems that everything is aligned correctly.
I assume that somehow the seat for the bearing race was damaged, and this was the fix. Should I be concerned about the strength of this repair? Prior to tearing the axle down, there was no indication of any problems with the knuckle.
What do you guys have to say about this?
Here is another pic of the shim
I'm not sure what to make of that, but it does seem well done. It appears the objective was to change caster, not repair damage. I base this on the deliberate forward movement of the knuckle swivel axis. Deliberate because someone with that skill level could have made the repair concentric with the original hole but they did not.
What's going on with the bottom of the axle housing - the other end of this picture? Also, have you opened the passenger (right) side yet? I'll be curious if there's a change there, also that would support my theory about caster change being the goal. Is your truck lifted, or was it? Also, I'd be curious if the axle seal (still in in your picture) wore it it's center or wore against the bottom (6 O'clock position) of the seal badly.
DougM
The other side is the way it should be.
It looks as if the race is exactly where it is supposed to be. I don't think it was moved laterally. The milling for the insert and the race is offset, but everything lines up with the axle itself, so this leads me to believe that nothing was changed in the alignment. It was moved in relation to elevation, hence the funky thick shim at the top bearing cap.
:confused:
i bet the insert was oval shaped so it would not be able to rotate. looks like it was just a fix to repair a damaged knuckle so the race would have a good place to sit.
Is there / shouldn't there be a matching one on the bottom if it were for caster? You only show a pic of the top. Could we see a pic of the bottom please? If it is for caster, that is sure a cool way of doing it.
Karl
That is an aftermarket caster correction bandaid, using an offset collar and a smaller trunion bearing.
I'm wondering if someone saw the usual low right side caster reading and thought it was a problem.
I've read about Camber bearings for these trucks and that looks to be what I'd expect just installed 90* out of position.
That device could be positioned at any compass point to change caster/camber.
In fact, I'm inclined to agree Rick that it's probably intended as a camber correction piece that has been used for caster.
I corrected the camber on my Dana 60 Dodge truck with tapered shims that go behind the spindles.
I took a good look at this today, and it is a caster correction fix. I have no idea why this has been done. My first thought is that the truck has been in an accident in the past, but Carfax has no reported accidents. Can an accident be missed by Carfax?
The bearing in the caster correction piece is smaller than the stock bearing. This causes me some concern, but as C-Dan pointed out to me earlier, it is the upper bearing, so it is not under the load that the lower bearing is.
I am going to put everything back the way that I found it. I had to source the smaller upper bearing, and it turns out it is a special order part through a local bearing supply. PITA:bang:
What would you guys do?
Would you get rid of the caster correction, or would you run it the way it is?
Once again, this only occurs on the DS knuckle. I am going to have the alignment checked once everything is back together.
Thank you C-Dan, Cruiserdrew, and Mudrak for all the good advice:cheers:
Hey Jeff-
With regard to Carfax missing an accident, they
certainly do...My truck was hit while parked, and damaged
to a degree of 16,400 dollars.. Nearly 70% of it's
total value..To this day, I have a clean Carfax...and
another victim of this same accident, significant damage
to their car as well, also has a clean Carfax...So much
for Carfax.
Thanks Paul. I think I'm going to look for a new axle to build! I'm going to put this one back together for now.
Hey Jeff-
for Carfax.
So by using these. Would that eliminate the need for a cut n turn on a 40 series that has been soa?
2.2* seems to be the max.... dont you need more than that for c n t?
Hey Jeff-
for Carfax.
Yup, my wife had the same thing happen 5 years ago. Really bad wreck (other persons fault). She was t-boned on the passenger side and she hit her head against the dirvers side window. E'Room trip to the hospital, with a stay, police, insurance, law suit, etc.
To this day the CarFax on her car is clean.
The only thing that a CarFax is good for is if it shows a wreck, you can be assured that the vehicle was in a wreck ;)
A clean Carfax is about as useful as tits on quail ;)
Fred
