Harness Help
im retro fitting to a '77 four pin plug...to replace it's brake, seat belt rectangle warning light(s)...so im thinking two bullet connectors as im going to cut that plug off.
i have a none op egr where the brake warning light should be, and am placing the brake warning light were the erg should be, but im shooting to have this one functional.
GoT it ,
2 Male Bullets < YAZAKI , OEM Green Tint Sheaths as well ..........
- i will Crimp Them on and report back with final progress photos
- in the mean time , food for thought : 🤔
- i keep in-stock every single LED update / upgrade Bulb configuration
that i am aware of for a FJ40 1963-1984 , also 99% of all color tone LED bulbs
in this various configurations also ............
- this is a good opertunity to make a quikie list of any you wish ot have not thought of upgrading and updating ...........
- Popular Plug and play request's i get all the time include :
- room lamp , courtesy light , in simple cool white 8000K
- under padded dash pull switch lamp , in oem green
- under dash heater lever control lamp , oem green
- high beam indicator , in OEM Violet , yes its refereed to as VIOLET lenses in microfiche ........
and then u can actually see the dam thing at night for once ....
- Tag frame bulbs , cool white 8000K
- rear side markers , oem RED
- front apron lamps OEM amber
- well there's a laundry list ,more too , But ............
my 1983 FJ43L-KC is 100% LED conversion , even the OEM FOG lamps too ....
- its do much LESS current draw and amp flow through your vintage harness
i simply consider it a Form of Preservation and nothing less..........
- now finally :
your headlamps ........
some will DISS this idea , but i swear by it , almost as if the Glass Lenses
were Made for LED bulbs , they have light and lumen direction flow to them
anyway . enough Chatty-matty 🤣
enjoy the Link and Please also go to main Page , scroll all the way down.
there you will find , a host of Icons , click on them and be taken back to
different TEq places in age and TEq time ........
enjoy ,
and PM me later , and well square up
i like trades too as we both found out recently ........
kindly
matt
start at the top with TECH video , of a BJ42...........
then work your was down to the interactive ones below .....
thanks matt
i have the dash pull knob lamp assembly...it was modified years ago to remove the green lense.
i haven't gotten around yet to repairing the harness to be able to use the heater control light...so going to pass on that one for now.
i tell you what , since you made my ARACO day , a few weeks ago . :D
im gonna toss in the heater lever led bulb , and mu KUSTOM made insulator ,
tabs , that u slide inside to prevent the bulb contacts from shorting to ground
it that TINY space made for HOBIT !
both lamps use the exact same bulb ......fyi
how does that sound ?
awesome thanks
do u want the OEM Violet LED high beam indicator update too ?
doing the green turn signals ones is plug and play and sweet sweet .
but non necessary
the i=high beam one is a safety topic in my opinion .........
all my bulbs lumen are SUPER MAX and out preform anything close to what super bright currently offers .............fyi
sure that would be great
ok Brian ,
pay close attn. to these details spec's please :
- you MUST install my Kustom Heater lever LED Bulb Lamp assy circuit
insulators , prior to bulb install
- they slide between the copper terminals B+ and the NEG- Ground and
are technically full blown insulators in every way !
- once in place depress my MAX Lumens festoon bulbs down one end at a
time till it clicks in place both sides ,
- rotate if needed so the 12 micro LED's face straight down and are centered
too in the small cracker-jack box housing toytoa dreamed up 50+ years ago
and never bothered to update ............
see pics below
- u have my Shop HOT LINE # , call me if u get stuck , but its really simple
in the end .....................
You Dig ?
Hey Matt, @ToyotaMatt , do you have an image of the radio kit installed? I'm under the assumption that the speaker mounted in the glove box, and faced the corner of the cowl? I put a modern speaker in there today, and would consider running the OEM one there if it worked with my CD player. I wonder if it has to match ohms, and watts?
hi brian
i have your needed Socket , please stand by for photos
would you like LED
or
Old Skool Incandescent ?
- if LED , what is your Lens color we are dealing with ...........
- if you pass on the LED option for some reason ..............
well, u might be regretful for the foreseeable future ........... :cool: 🦄 :wrench::wrench::wrench:
Hey @ToyotaMatt !
I am restoring an Aug '75 and need this same EGR light socket. I have the EGR lens housing but not the bulb socket/wires. Do you have an old school one for sale?
