Hello everyone,
My 1992 HZJ77 had a H55F transmission and vacuum shifted split case transfer and I changed the whole transmission with what I believe H55 transmission with standard shifter transfer case. Everything bolted on fine but I now can't get acceleration as before. The car sounds and runs as it is shifted into low gears. In 5th gear I get only 50km/h showing about 3000 rpm. What might be the problem with this? Transmission shift fine but I can't shift to neutral also.
Thanks,
Davaa
Thanks,
Davaa
