h55 and transfer case
south carolina
hello everyone. i need a little info. i am going to be purchasing a 12ht and h55 and vacum shift transfer case for my fj60. what do i need to add to make the vacuum transfer case work on my fj.? i will also be changing 24volts to 12. i have already bought an alterantor and starter for the change over and trying to get all my parts on the shelf before i get into it. thanks
Are you wanting to keep the vaccuum actuation? If your 60 is 8(?)/85 or later, you should already have the split t-case. I would think you could just pull the manual shift components off of your existing t-case and swap them with the vaccuum actuator on your newly-aquired case.
mine is an 87 that sounds easy. i have read about guys who drilled and tapped a whole and just mounted their 4speed transfer to the 5speed. not sure havent seen the drivetrain yet, to know for sure
But both are the same bolt pathern .. it means you where been hable to swap the you tcase with the H55F
do i not need to create a way to get oil to the 5 gear?
I mean ( correct me if I'm wrong ) you have a complete H55F with a vaccum t-case and your factory tranny that comes with a split case also ..
If you run the complete H55F there is no worries in the oil department. so attach behing it the factory ( that comes in your cruiser ) t-case and you are done ..
this doesnt work. the high/low shift lever is pointed a different direction, and the shaft coming out of the front of the case where the vacuum unit is is ia different length
What tapage is saying = use the split case from your 4 speed. Lots of people that buy new h55 trannys use their 4 speed case. Search the 60 forum and you will find all you need to know.
Or just use the vac shift. The parts are not that expensive. You will need the dash switch and solenoids from a 62. You could get all the vac lines from a 62 as well or make your own.
And you will have to wire it yourself. I have not done it, but it cant be too complicated.
would be nice to see some completed pics of this particular conversion. If you look at the pic in the first post you will see that the high/low shift lever on the tcase is pointing towards the trans and moves in an ark totally towards the trans (this is the lever for a vac shift case). The shifter in this case moves front to back to select high or low.
The shift lever on a manual shift tcase points forward in the same direction as the front output and moves in an ark in the same plane as the front half of the tcase. The lever is also 1-2" longer. The shifter in this case moves left to right to select high or low.
That conversion pictured with no other changes would require a twin stick setup.
I have a thread in the 60 section that I need to complete. I put a manual shifter on a vac transfer that is still connected to an auto trans.
if everything goes right i should be picking up the drivetrain saturday and will post some pics of the 2 for comparison and to see if i will be capable of doing this.
hey anest, i am just finishing up doing this on my overland project. I ended up making my own solenoid from the $18 mini-truck units and wiring in a new circuit. If you decide you want to keep the vacuum shift feature, let me know and I can help you with the wiring etc. It's not that difficult, or expensive.
nice score on the 12HT! Are you going to be at the UC BBQ saturday?
hey gehn , i will definetly get in touch with you about the parts lists i will need. i dont know if i will make it to the BBQ because i am supposed to go and pick up the drivetrain. are you going to be driving the cruiser there?
question,
why not just run the VSVs and be done with it?
modifying the shift lever cover on the floor is no biggie... a couple VSVs from the junk yard will work fine.
