GX460 Caliper/Rotor Upgrade for GX470
So Cal
If your GX470 front calipers need to be replaced because they are old or they are stuck/seized, here are the parts to upgrade to the bigger GX460 calipers/rotors
GX460 Front Caliper/Rotor Upgrade
  • 47730-60300 GX460 Right Front caliper is larger to fit the thicker GX460 rotors
  • 47750-60300 GX460 Left Front caliper is larger to fit the thicker GX460 rotors
  • 04945-60090 (1) anti squeal shim set (invoice says two but Bell Lexus corrected and refunded one)
  • 04947-35050 (1) Anti-rattle springs for upper and lower (optional lower)
  • 43512-60191 (2) Gx460 front rotors (thicker by 1/4”) help dissipate heat better
  • Front ceramic brake pads Akebono ACT976 same as GX470. Or your favorite GX470 brake pads
Adding AI’s take on this….
🛠️ Why GX470 Calipers Seize More Often
The GX470 (and 4th‑gen 4Runner, and 120‑series Prado) use a 4‑piston fixed caliper design that is notorious for:
• Corrosion forming behind the piston seals
• Pistons sticking in their bores
• Uneven pad wear
• Dragging brakes and overheating
This is a well‑documented issue in GXOR, IH8MUD, and 4Runner forums. Toyota never issued a recall, but the problem is common enough that many GX470 owners replace calipers every 60–100k miles.
The root cause is the piston/seal design and the caliper’s susceptibility to moisture intrusion. Once rust forms behind the dust boots, the pistons no longer retract smoothly.
🚙 Why GX460 Calipers Are Less Likely to Seize
When Toyota moved from the GX470 (120‑series) to the GX460 (150‑series), they updated the front brake system:
✔️ Larger, thicker rotors
• The GX460 uses a thicker rotor, which requires a larger caliper body.
• This redesign also changed the piston layout and seal geometry.
✔️ Improved piston seal design
• Toyota revised the dust boot and seal arrangement to reduce moisture intrusion.
• This is the biggest factor in reducing seizure.
✔️ Better corrosion resistance
• The GX460 calipers tend to resist internal rusting better than the GX470 units.
• Many GX460 owners report 150k–200k+ miles on original calipers with no sticking.
✔️ Reduced thermal load
• The larger rotor dissipates heat better.
• Lower heat = less seal degradation = fewer stuck pistons.
🧠 Why the Upgrade Works on a GX470
The GX470 and GX460 share the same knuckle mounting points, so the GX460 caliper bolts right on. You just need:
• GX460 calipers
• GX460 rotors (thicker)
• GX470/GX460 pads (same part number)
This is why the upgrade is so popular — it’s a direct bolt‑on fix for a known weak point.
📌 Bottom Line
Yes — GX460 front calipers are significantly less prone to seizing than GX470 calipers.
Why?
• Improved piston/seal design
• Better corrosion resistance
• Larger rotor = less heat stress
• Toyota quietly fixed a known issue from the 120‑series platform
If your GX470 calipers are sticking (very common), the GX460 upgrade is the most reliable long‑term solution.
There are two part numbers for the calipers they are side specific due to the brake line and bleeder location.
You are right…I looked at my invoice incorrectly. Fixed it and included my invoice
Are these direct bolt on? No modifications needed?
Yes. You're essentially changing the caliper and rotors up front to 460 stuff. I believe the front pads are even the same between 470/460 but I could be wrong.
I did this in 2021 about 50k miles ago and have never looked back either.
I don't think you actually want the small parts with the Akebono pads, they have the shims permanently affixed, and between the pads and the factory caliper set I just bought I had more than enough anti-rattle clips.
Is this part number for '10-14 GX460 calipers? i recall reading they changed them on the '14+ and the calipers had larger holes or something.
Yes, part numbers are for the 2010-2013 GX460 which uses the same bolt size as the GX470.
In 2014, the GX460 calipers use a thicker bolt. You can buy a bolt sleeve to fit the 2014+ calipers on the GX470
thanks for confirming! I'm going to take advantage of the sale going on at Bell Lexus and pick up some calipers
470 and 460 rears are the same size.
Did my fronts to 460 calipers and 460 EBC rotors with EBC pads.
To clarify, the rear calipers are the same. The rear rotors are not.
While you can technically put a rear 460 rotor on a 470, you will get a horrible clanking/scratching noise while driving. I had to learn that the hard way.
You are correct. My statement was misleading about the possible interchangeability between the sets. The calipers are the same, the 460 rotors have a different bore and offset to match the new 8.5 rear diff. Small as the differences are, you know it doesn't work. My point was that there isn't a rear "460 upgrade" option for the 470, just better stock components.
Thank you my friend for clarifying. My bad.
Mine ended up in the scrap metal pile. Looks like folks are selling them on eBay for around $50-75 a caliper! Should have done that with mine as I probably got $1-2 out of them in scrap.
