GX without Nav reverse trigger wire for aftermarket backup camera.... Found it
Jensen Beach Florida
I installed a backup camera in my 05 no nav GX today and I needed to find the reverse trigger wire to give signal to the head unit when I put it in reverse. After searching the internet for a good while with no luck, I got out the volt meter and went to work. It was pretty tedious, but I found it. Behind the kick panel on the drives side, there is a white plug that goes into the blue with a 10mm bolt on the end. In that plug, it is the thicker red wire with the black stripe, second from the top, on the outside. Just tap into that for your reverse signal.
Just in case anyone ever needs it, there it is.
Just going to bump this to ask if anyone knows if it's the same wire for a 2003 with NAV. Thinking about putting in a backup camera.
Just tap at the taillight assembly, the reverse wire powers the camera so you'll be needing it back there anyway. When you run the RCA video feed, piggyback that wire to your stereo for its camera trigger.
The question is which wire activates the video feed when putting it into reverse. I was trying to confirm if the red wire with the black stripe is the same to tap in the nav, because this post specifically mentions the non-nav.
I re-read your post and I think I'm confused. I now get that you were saying to power the camera from the taillight assembly, but then how do you connect the rca to trigger the video feed when you put it into reverse just by connecting to the stereo? Doesn't the RCA have to go to the stereo unit anyway to show the video feed? Thanks for your help.
If you're trying to tap a camera into the factory NAV screen I believe you're outta luck. I didn't know the '03s came with NAV but no camera. The aftermarket camera will feed video signal any time it's powered, so if you power it off the reverse lights, it'll always feed video in Reverse. I'd look into a rearview mirror with video screen built in and route my camera signal there.
View attachment 1346914 View attachment 1346913
several years later, this thread still helps! I ran the trigger to the passenger side per instructions from Crutchfield; ended up being a constant hot wire.
The driver side footwell with this wire is the way to go! Thank you so much!
for real! I've been troubleshooting an issue with a new install today. Thought the canbus decoder would trigger the reverse, but I may have to do this instead.
