I have J springs in front and was running the OME 2 degree cc bushings. I was getting a slight grrrr noise only when getting on or off the throttle. Under steady power no noise. Coasting no noise...
I recently acquired some F.O.R. 3 degree cc bushing thinking this would fix the problem, thinking the J's produce about the same amount of lift as the F.O.R. springs. I have an ARB but no winch.
The noise is still there!
What's the best course of action here to getting the grrr to go away. I was living with it before but it's pretty annoying at this point since I've done the cc bushings now twice on my truck.
So the question's are:
1. Replace the u-joints?
2. Replace the springs with F.O.R. springs all around?
3. Buy a double cardon shaft and hope that does it?
What would you guys do?
p.s. No, i have not taken any caster readings.
Thanks....
Eric
Thanks....
Eric
