Ground strap. Where does it go...
Putting my junk back together and found this ground strap. On the passenger side. Can't figure out where it goes.
Goes from the passenger side of the block to the firewall, just behind the bolt that holds the wiring harness/heater valve.
Interesting. I don't have that in my LX. I need to see what's up in the morning.
Edit: then again my engine has been out twice so anything is possible :meh:
Hey hopefully you have a lift brackets on your engine head. I decided to reinstall the drivers side one after I installed the upper manifold. Now I got no lift bracket. The injectors are in the way of the bolt holes.
It was on my LX before I upgraded to a bigger wire.
Sorry for the stupid question. But does it go behind the plastic on the firewall or in front of the plastic with the bolt?
Fourrunner makes a heavy duty replacement set that are super beefy. I put them on my rig and was pretty impressed.
