Grinding noise After Shackle install
I just completed mounting front and rear shackles. 3" longer than stock in the rear, and 2.5"longer in the front with 4 degree shims. New shocks, bushings, the works. Once i got to 2nd gear started to hear grinding and as i accelerated in 2nd the noise got louder, i haven't made it to 3rd yet. this is a 1970 fj 55. Is it possible that drive shaft or axle modifications are needed? Steering and brakes seem fine and the ride is great, but why the horrid noise. Maybe its just finding its new groove? wishfull thinking
I am assuming you looked to see there was no rubbing or contact anywehere with the tires or axles.
Try taking the drive shafts one at a time and run it in 4WD when you pull the rear. See if that makes any difference on the sound.
When you have the shafts off, rotate the U Joints to see if there are any dead spots.
I am assuming you started with stock by your post. Lifst increase the angle for the drive shaft at the pinion plate (diff side) worn U Joints will show the angle difference with grinding.
This alos happens sometimes when the internal shaft is over greased. The fix for this is to mark the shaft so you can get it back together the same way and clean out around the spline and regrease by hand.
If you replace any U joints, I recommend you have th shaft balanced.
Good luck!
Maybe try and see if its something real simple by jacking up the front and rear separately, and spinning the tires by hand.....just in case somethings rubbing. You may find something real stupid!! Go easy first!! :grinpimp:
You can also put it on 4 jackstands and have a buddy run it (ready on the brakes) while you carefully look for the noise. For safety purposes I'd advise that you do it in a clear area without kids or other cars or houses nearby, and I wouldn't get under it either. I think Romer is onto it with the Ujoints.
It was real simple, i finished up as it was getting dark. when i was working on it i had it in 4wd, because my parking brake doesn't work. And, well, i unlock the hubs, pushed in the H-H-L lever and left thF.D. out. So basically I'm an idiot and it all turned out sweet. Good thing i didn 't put it up on all fours and ralley it through the nieghbors fence>logger
I had the 4wd engaged during the installation. When i finished the install i disengaged. I unlocked the hubs, Then i push the L-N-H lever back in. But i didn't push the F.D. engagement lever all the way in. So something was kind of engaged, which was causing the grinding noise. A lesson in Check and double check the obvious first.
