Green T-Case, leaky speedometer
For the leak at the transfer case where the speedometer gear is, I used some Permatex non-curing automotive sealant. I smeared a thin coat around the o-ring area, reinserted the gear, and haven't had a leak since. Because this is non-curing, you can pull and reinsert any time with the same results.
(Sorry for the bump, figured this might help someone.........)
I've got a bad o-ring that I haven't replaced yet. In the FSM the procedure is in the transmission section. So, just to verify, am I leaking transfer fluid or AT fluid?
just finished up with this little job, thanks again to all everyone that helped me out. Very easy and straight forward, like you said it would be.
I was a little concerned with the amount of dirt that was around the speedo housing, is this about normal? I was sure to wipe it all clean before reinstallation.
what size o ring did the trick any recollection?
Holy old thread man... this was 14 years ago! The o-ring is a Toyota part, don't recall the part number but suspect any of our current parts vendors on here would know what it is and have it in stock.
lol, thanks man
Should'a kept that 80 man!
Just to get the P/N's on here (as someone asked) for the FZJ (could be others too) since I'm seeing a little drippy-drip as well...
(parts gurus - please correct if necessary)
90310-09001
SEAL, OIL
Toyota 90310-09001 SEAL, OIL
Part DescriptionSeal, Oil (For MTM Speedometer Shaft Sleeve)
96711-24030
RING, O
Toyota 96711-24030 RING, O
Part DescriptionRing, O (For Speedometer Sensor)
July 2020 cost - about $7 for both +shipping from TPDdotcom
Yer gear oil is fine.
You need to replace the o-ring on the outside of the speedometer driven gear sleve.
As I'm home at the moment sipping on a bubbly delight, I can't recite the part number :flipoff2: .
It is indeed an easy fix.
D-
G'day CruiserDan going through the old threads again. Just wondering if you managed to get your hands on the part number for the Speedo O ring?
ha! I love it when old threads of mine get bumped up... going on 20 years for this one! You guys do your 2nd row recliner hinges yet? keep searching, lads... carry on. :cheers:
