Hello, I have a 1995 Land Cruiser w/triple locker. The other day I noticed I had grease or oil on the rim and tire of my Passanger-side Rear (see attached picture). Is this a sure sign that I am leaking differential fluid and need to replace the rear axle seal and wheel bearing? I'm going to take the wheel off today to take a look but just wanted to know if this is a common sign.
: once your finished working on the axle, lift up one side, let gear oil into the hub on the other side, level, add gear oil to the pumpkin, lift other side, let the oil run into the opposite hub, level, top off the pumpkin again, and call it good.
