Does your High Beam indicator work?Looks like it's been covered already but just to confirm, I put these in my 45 last year. Install was easy.
Ha, this sounds familiarNot sure, like I mentioned, I rarely drive it in the dark. The bit I have used the lights probably was low beams only. It's mothballed until spring now and by the time the salt is off the roads it's light until 9 and that's not much before my bedtime![]()
I did actually have a bit of a search on that site, but only found this one.You can probably find the 24v relays on digikey... Just need to check the pin out
Forgot about them. Time to bust out the million page catalog.Greggs will have them. They’re pretty common.
Yeah, I have lots of the hellas. Clearly not as many as youA few of the ones I have here. Those numbers should help you.
I'll only need sockets if I strike out on finding relays that'll fit the harness..Are you looking for a socket for the small Toyota relay or this larger one?
Cool. Turns out there's a wajax 5 minutes from me.Call the parts counter at the closest wajax branch, they’ll get them for you. I see them all the time with different pin counts.
Ha, it won't bother me lol, just wasn't sure till I pulled out the relay that the socket had a slot for it.Normally the extra pin is a second output that's the opposite of the first one... IE NC vs NO...
Can usually use them anyway or cut off the pin if it really bothers you
