I have an intermittant miss that I am trying to track. F engine, standard exhaust. "NonUSA" Aisen carb and dizzy.
The miss seems to come about every 6-7 beats/cycles. In other words, the rate of miss is 1 miss per 7 sparks to a given cylinder. I detect it at the tailpipe easiest.
Each of the spark plug wires seems to spark regularly. I cannot determine that one or another cylinder is the one that is missing by removing spark plugs and holding them and grounding them to check the spark regularity. All are regular.
I checked the resistance on all of the wires, and they are symmetrical.
I don't see any damage to the rotor head or button or cap.
I DID notice that when using my induction timing light, I did not get a signal from the number 1 cylinder wire, and switched it for another wire that did give a signal. But that did not change the miss.
I played with the timing, but could not eliminate the miss that way, and I checked the dwell, which was 39 degrees: I guess that should be ok.
I have not yet pulled the plugs to inspect them, maybe tomorrow.
Any thoughts or recommendations?
