Ghost starter!
Wyoming
I went to start the cruiser this morning, and it made a weird sound and then stalled. I turned it off, then back on. It was making a different weird sound, so I shut it off again. I went to dig out the snowblower for the driveway and I look out and see the cruiser turning over, but not starting. I go out, put my key in and turn it off and on and off again. Hasn't done it since, but it's freakin strange. Ignition switch?
Search for starter contacts.
cheers,
george.
I searched, but it doesn't seem relevant. Maybe I'm not seeing the right posts
Do fix/ replace.
My 94 had this issue, engine would start but starter would continue to run until I disconnected the battery. Luckily I had installed marine terminals so that part was easy. I just replaced it with remanufactured. Didn’t have time to fix it.
Sounds good. I will get going on doing the contacts.
Question though. Yesterday during this thing, I had turned the car off. And it was off, nothing running, and like 3-4 minutes later it started cranking on its own, after being totally off. I was able to shut it off by using the key. Is there anyway the ignition switch could malfunction and cause similar symptoms?
Possibly, but worn contacts are a known issue and are easy to address.
If it were my truck, and I had witnessed the starter engage by itself without the key on, I would absolutely disconnect the battery until you figure this out. If you had not been around to intervene, it is likely that your truck would have caught fire and burned up. It has happened before.
It's disconnect at this point. I will do the contacts before reconnecting. I appreciate the input. Looks like I need to order some contacts before anything else.
I have a spare 94 engine with a 28100-66060 on it. Can I swap that one over and rebuild the original when the parts get here, or never, for that matter?
Mine as a 28100-66050 as of right now
Yes, externally interchangeable as far as using one versus the other.
cheers,
george.
^^^This^^^.
Be sure to get the correct parts for your 2.2kW starter if you rebuild it,
they are different from the 2.0kW starter you plan to install for now.
Another rebuild thread with part numbers:
Well, I swapped out starters. It didn't turn over, so u pulled it out and jumped it. It worked fine. So I sanded all the contact surfaces and put it back in. It fired up. I think it was just sitting for a while and needed too be cranked a few revolutions I will let it sit for a free hours and go crank it again.
