Having an odd starting issue. Truck has been cranking and running fine until this past weekend when it was extremely cold. First two or three attempts were just clicks then the truck started fine. Last night it clicked a few time, turned over normally but would not start. Every so often it would stutter a little like it was getting fuel and spark. This morning I tried it again and it just clicked. Tried jumping it and it attempted to start but then the starter would disengage. I had the battery checked and opted to replace it. Installed the new battery and while it's attempting to start, the starter is not stopping even when the key is removed. I had to pull the battery cable stop it. Working on removing the starter now to replace it since the truck has 234k on it and the starter is a reman. I've reset the ecu, run through the not starting checklist of fusible links, cables, relays, searched the forums, etc....
Anyone seen something simliar?
