he 60 out....if you want anything, PM me.
View user's profile Send private message
dumbdunce
PostPosted: Fri Oct 28, 2005 6:05 pm Reply with quote Back to top
vanzbrown wrote:
carts wrote:
joel HJ60 wrote:
What did your entire turbo + intercooler setup cost?
if that question was aimed at me, it cost about $3800.
That includes new turbo, manifold, exhaust, installation, plumbing, intercooler core, intercooler plumbing in 3 inch stainless steel and blow off valve and boost gauge.
I think it was a reasonable investment.
Thats a cracker of a price... How much of that included work you did yourself and/or mates rates...
Thats sensational armsup
Leeroy
I installed the turbo, which was around 2800 installed from memory. it is a Denco kit with schwitzer turbo and includes full exhaust. the Intercooler was sourced on
ebay, around $300?, Carts mounted it himself, we cut some holes in the radiator support panel for the plumbing, and the intercooler plumbing was supplied and installed in stainless steel by a reputable exhaust shop. we then found that with the air volume in the intercooler and boost over 10psi, boost was spiking (off the top of 15psi gauge) due to the throttle butterfly used to govern fuel delivery, so a BOV was sourced on
ebay modified to work with the very low vacuum generated in the 2H inlet, then installed to the intercooler plumbing.
with a bit of imagination and perserverance its possible to do a custom turbo on a 2H with a second hand import turbo for very cheap - possibly as cheap as new extractors/full exhaust - and even if the turbo costs a few hundred more, the extra power is definitely worth it.
Although the 2H is not the best candidate for turbocharging, cart's one is standing up to 13psi quite well - the key thing is to keep the EGT's low - IO think we have his set up for 500C max post turbo.
It keeps up with (ok it's slightly quicker!) than my 80 series factory turbo multivalve.
_________________
