Gear Whine ?????
1996 FZJ80
143000
Extensive service history from toyota dealer
front end completely rebuilt except trunion bearings, other all new
non-locked
never offroad unitl I bought 6 months ago.
stock michelins
Going donw the road, any speed between 25-75 and let off the gas there is a whine from underneath. There is no vibration associated with it. I have built and wheeled many toyotas, even built and wheeled an SAS Taco, never whine like this. No leaks at pinion seals and gear oil is new factory toyota as well as the transfercase. 4x4 works perfect, truck is perfect other than the whine. I did not know whether this is a charecteristic of higher mileage 80's because of the viscous coupler or something like that. Thanks for all input.
PS no metal in diffs, checked that first.
Yes it varies with speed, (I know they are full time, I meant the 4x4 functions of the LC, like low range work with no issues or noises). I just read a very old thread about noises and it said something about the output bearing on the transfer case?????
VC will occasionally fail due to running mismatched tires or otherwise doing something that causes the silicone fluid to harden and lock up. We have many with very high mileage and no problems so failures are not directly related to mileage. As I recall, a bad VC doesn't whine though.
It could be a transfer case bearing. There are several good "how-to" threads on replacing the TC bearings.
-B-
I appreciate all the good info from you guys, truck did have bridgestones on front and michelins on rear, were the same size by numbers, but I am familiar with the size differences between manufacturers. Driving today, I shifted into neutral at 45 and 55 and the tone changes slighlty but the noise does no go away. I have seen ring and pinions that are noisy under load and then lessen when load is lifted. No real change here. Seems to be tranfercase to me as well. I will continue my checking, especially guide about the bearing changing in the posts. Thanks again.
gear whine
Well with 143k you certainly could have some wear. Does it sound like the front or rear? Typically a noise on decell would be pinion bearings/worn ring & pinion. Do you intend to leave it stock? We actually stock OEM 4.10 ring & pinions that are price much less than from the dealer.
1996 FZJ80
143000
non-locked
stock michelins
I have the same whine in my 97 FZJ80 with 179K. I have rebuilt my rear diff, replaced tcase output bearing, replaced all wheel bearings and races, replaced tcase mount, and replaced u-joints. I use the water hose method to pin point noise. Although I still have a whine, just as you described, it changed with each repair. On a good day I can click on the cruise control and have a quiet ride. The other days I turn the radio up. Next step is sound proofing.
P.S. My wife has yet to hear a whine.
I will switch to redline this weekend and see what happens. Just aquired a transfer case and a front and rear axle with factory lockers. If noise continues to irritate me I will change them all
I'm placing my bet on ujoints. If you haven't done it yet, I would pull the front DS, engage the CDL and drive around and see if you still hear the whine. Then do the same with the rear DS. (obviously reinstalling the front DS before you pull the rear one):hillbilly:.
Could also easily be slop in the slip yoke. Good luck but my guess is that with the service history etc its not going to be one of the big ticket items that your fear. Probably still running original factory ujoints and they just need to be replaced (possibly the slip yoke as well).
I have thought of the ujoints and multiple times have gotten under the truck and look for tell tale signs, then jack up all four corners and put trans and transfercase in neutral and felt no slop. I know this is not a satisfactory indication that there are still good, I am almost sure that they are original, or at least very old. They will be changed as well.
