Gear Shift Lock
Got this on the mail today...
Seth, I dont know if I can bend this piece of metal myself?
It is 1/4" thick..... got any suggestions...
I figure worse case scenario I cut it and welded back together....
I like to use those carriage holes/bolts it came with....
I like how KR installed his... simply out of the way until needed...
Here it is..
It had to be cut and welded on the side the bends were done by grinding some of the metal off and once the right angle was achieved, hot metal was added...
With that said if I was to do it I would probably install it more to the driver side and not in the middle like I did...
Reason is, it flexes (a tad bit) when you pull on it when locked, but no it will not budge.
Also, where I put it I missed the support tab for the lighter by a few millimeters and drilling the holes at that angle was a biotch ( guess this last part is more about not having the right tools)
If you install it more to the driver side you are much more closer to the support that runs along the steering wheel....
Other than that.. I think its a good security device...
I did not use the snap off nuts that came with the kit.. I used grade 8 th nylocks instead
I found your thread on the lock MaNu. Thanks for posting this. I'll get the same set-up. Before I do though, do you have any thoughts of it post install? Would you change the location still like you mentioned above?
Nick.
I would def stll put the lock more to the driver side..... just cause there is more support on that side... or put a backing plate behind that section, and i'ts out of the way.
Im sure if they want the rig that bad they'll get it ....but not before putting up a good fight against this lock...
Why do ONE kill switch... when you can do MANY more....
If they want it that bad.. makde them MOFOS work for it... !!!
That's whay I say
Trouble with GPS is they want like 20 bux a month to monitor... That adds up fast. Almost as much as my regular insurance...
If a carrier truck pulls up behind your car and winches it up, like the tow trucks do, there is little that can prevent that.
But that is not very common.
This product looks like it would work pretty good....The ultimate kill switch, but looks like you would always have to have the male FOB with you (or hidden), which would kind of suck. Have never tried it or heard of anyone using it. Just found it with a web-search. But it is expensive (over $400) and it looks like a factory rep has to install it. Not liking that idea...
Ravelco
http://nohotwire.com/
Defeating a Ravelco
http://nohotwire.com/uncategorized/defeat-ravelco/
Nick.
That's whay I say
Great. When I get mine back from the repair shop, I'm going to get some measurements and see what they can do for me.
Many kill switches.... interesting. I might hook the previous owners switch back in then.
make one of your kill switches your cigarette lighter (unless you use it a lot). there was a guy on the 40 section who did that I think. who would ever think you had to push a cigarette lighter in to start your truck! I thought it was a pretty cool idea
