Looking for a gear shift lock for anti theft. Can anyone point me where to purchase and how to install?
Anthony
Anthony
Just get the shifter removal SST and pull the shifter out when you want it "locked". It is almost infallable unless the thief specifically wants your rig and knows your trick.
Here's the one I've got. I bought it in New Delhi, India.
http://www.xenos.co.in/gear-shift-locks.html
Maybe you can order one - I think it's awesome. There are many different bracket configurations. The one that I bought (just eyeballing it in Delhi 6000 miles away from my Cruiser) was the bracket for a Mahindra Scorpio (1st or 2nd generation) It worked perfectly with a little bit of bending.
And it was pretty cheap and has been used everyday since 2008 with no issues.
Mines mounted to the left of the gearshift lever and locks it into 1st gear. The bracket also made a nice mounting platform for a VHF radio speaker, a pyrometer and a boost gauge.
Also, if you going to to through the trouble of putting a kill switch you might want to spend the extra time to install a couple of them....for piece of mind... just saying..
This is what the a side bracket install looks like. Lot's of room for things attached to it. The flat spot of the bend is where the radio handset sits.
The metal bracket does a radius curve over the transmission hump below where it comes through a slit in the carpet. Lots of room underneath to bolt the bracket to the metal of the tranny hump...
