Gauge Cluster Flickering LED Lights
Hornd
Toledo, OH
I learned something the hard way so I will share my experience.
I put the T10 Bulbs in the Gauge Cluster. Appreciate the White Light & added Brightness, but they flickered so bad, I wanted to punch the dash.
Assumed it was bad connection so removed all again, bent up contacts on the sockets, and cleaned the copper rings that complete circuit on gauge.
They still flickered and I was going to put old bulbs back in. It will literally drive you that crazy.
Called SuperbrightLEDs and asked them and they said I should try CANBUS Leds with Resistor built in.
I ordered some and installed and flicker went away.
Going forward, will only be using CANBUS LEDs as the Rear License Plate Lights are same size and flickering constantly.
I bought the original LEDs from a Mud Vendor, but I'm unsure if they actually tried them.
10 LEDS can be had for $18 with Free Shipping.
Search Ebay: 10 PCS HID White CANBUS T10 5630 6-SMD Error Free LED Light 194 192 158 168 2825
Hope this saves someone the same headache I experienced.
It's not the fault of the LEDs themselves. The problem is that a vehicle has lots of electrical circuits, solenoids, electrical motors and other stuff which causes momentary (miliseconds) voltage peaks (maybe even up to 50V). An incandescent bulb is not affected by this because inside there is just a metal wire which would need more time to be heated up by such a voltage rise. A LED is a semiconductor and even a very short pulse of high voltage causes damage which adds up over time causing filckering and then death. Please also note that LEDs use resistors that assume you have 12 volts but with the engine running you get up to 14.4V
One way to address this issue is to install LEDs whch are driven under their maximum specs. Usually a stronger resistor is used. But over time the same problem might appear, only later.
The better way is to use a voltage regulator (google LM7812) which costs around 30 cents and can operate upt to 1.5Amps. So ideally you should find the wiring for the gauge cluster and insert the regulator before all the LEDs. This will keep them safe for the next 20 years.
So my conclusion is that any LED with only a resistor will start to flicker sooner or later. Only a voltage regulator will solve the problem. I have some LED strips which were installed 8 years ago and not a single LED is flickering.
I will report how long they last.
Seems that the variable resistor may play some role as well.
When the dimmer is turned down they seem to want to stop flickering, but brightness is compromised.
Thats weird. I have tried out more LEDs than I would have liked trying to find the perfect light output. Never had any issues with flickering.
Few months later and I'm very interested in how this works for you .. since I have the LED dash flickering too ..
Did you use the Canbus LEDs I mentioned above in post Numero Uno? If not order them up.
I did order them yesterday but want to order backup from superbrightLED ..
There is NO canbus requirement on a 80 for the LEDs.
As MikePL stated above, the LEDs are electronic devices that are sensitive to voltage spikes. Most all little bulb replacements use a LED and a series resistor to limit the current from a nominal 12 - 14V power source. That resistor does nothing to protect from high voltage/short duration spikes and THAT is what damages the semiconductor of the LED. That damage often shows up as flickering in the LED during operation, often just a prelim to total LED failure.
A so called Can Bus LED is just a LED with series resistor PLUS a parallel resistor that draws as much current as the original incandescent bulb that it replaces. That current draw is to 'trick' the Can Bus system to think that the 'bulb' is ok (i.e. filament not blown) since a LED draws a lot lower current and can appear 'burned out' to the Can Bus. We don't have Can Bus detection etc.
The parallel resistor of a so called Can Bus LED can help to 'absorb' some of the spike energy to somewhat protect the LED, but it doesn't guarantee long term protection - all depends on the type of spikes present AND occurring while those lights are actually turned on.
For larger bulb replacements (brake lights, turn lights etc) choose a LED unit that has an electronic constant current driver (this will protect from spikes etc if properly designed). Don't use larger bulbs made up of many 5mm (etc) LEDs since they will typically just use a resistor in series for current limiting and you'll face the same spike damage issues and eventually flickering.
I've seen Can Bus 'devices' sold as accessories to enable LEDs to work in Can Bus aware vehicles. Several dollars for a resistor (inside heatshrink) and a lead out each end... :)
cheers,
george.
Mine started to flicker also. I just adjusted the dimming knob a little bit, and the flicker has gone away.
Thanks George .. so we have no hope with LED for our Dash .. ? ( smaller LED )
Well, it all depends on how the small LED indicator is implemented (any kind of spike protection) and what the spike situation is like in a particular vehicle.
Some folk have retrofitted leds successfully, I guess we need to know if they worked fine long term. Since the spike damage that leads to flickering can take weeks/months, we don't often hear back whether things have worked long term or failed etc...
I've stuck with incan bulbs in my vehicles, they last a long time. The D is the only 'bulb' that died in my 80 and I replaced that with a homebrew LED and it's been good for many many years.
cheers,
george.
and those you use in your vehicle you add some electronic constant current driver to the mix to help last longer of it's just about the quality of the LED used ..?
and if it's that which it's your recommendation .. since I have the early 80 dash model, it's not an easy job to the the dash out and I rather not doing it every 6 months
