Gates V-belt failure
I was doing a quick check of my 94 FZJ 80 today and noticed that one fan/alternator v-belts had almost no tension in it, the other looked fine. I had new Toyota belts lying around so I switched them in. When I removed the v-belt that had lost tension I noticed it was really distorted, instead of the bottom of the "V" being on the inside of the belt the side of the "V" was on the inside of the belt for a good portion. Otherwise the belt looked fine.
The belt that failed is a Gates 3V450 that has been on the cruiser for 4 years and about 10,000 miles. I has thought it would be safe to use non-Toyota parts for something as simple as a V-belt. I will not be making that mistake again.
I also had one twist a while back. Toyota belts are very robust and don't cost much more.
HUH. I had only heard that they're much noisier.
I'm not sure about that. The gates belts around here run 20$ tops IIRC while I paid $70 to the local dealership.
Keep an eye on the new belt and see if maybe something like a pulley mis-alignment is the issue. Or it could have been not installed right to begin with. I wouldn't write them off because they do make good belts
Nothing wrong with Gates belts, all belts will roll if they are not kept at tension and or the pulleys are worn.
I don't know if car manfacturers do this but belt manufacturers have a tension for new belts that is a bit higher than used belts to allow for the belts to settle in. Because the engine vee belts are so short I set to recommended and run the engine for five minutes and check and retension if needed.
edit. 4 years is 2 years over recommended replacement, so saying that it is faulty Gates belts is a bit of a stretch. (pun intended)
