Gas Tank Pads?
Tampa
The area below my gas tank had some rust that I just ground out today with a wire wheel - no rust through, just surface rust and some pitting where the original gas tank pads were. What should I use as a pad/spacer for the tank? I would like to use a material that doesn't harbor moisture like the originals. I'm thinking some rubber set in place with a heavy duty adhesive to keep the moisture out. What are your thoughts?
Oh, and word to the wise - check the area below your tanks as it is prone to rust. I found all kinds of junk in there. On a positive note I found the original cap with the shift pattern on it for my xfer case shift knob ;)
Nomis, I used strips of mudflap under mine. I did not stick them down, but will when I reinstall. The thickness of what you put under it is kind of determined by the gas tank straps, that's why I ended up using the mudflap.
HTH
Ed
X2 on the mudflap. Instead of strips I made mine the size of the tank and cut out the portion where the tank protrudes downward. It stays in place and I don't have to worry about it working out as it goes all the way around.
Me too!
That's the place I found mine! Along with some condom wrappers that I must have lost from High school (80-84)
I use 1/4" slices cut from 1" diameter rubber stoppers and glue them to the tank in 4 or 5 places using weatherstrip adhesive. They work great and minimize the area of the tank in contact with anything.
