Gas tank location
I did too, but there is a guy here in town that has a '67 that has the filler on the driver side rear below the tail lights. There is not a filler on the passenger side at all. At first i figured that he had an auxillary tank, but i was wrong.
that's what i thought.
not sure where it was on the 25's. but i thought the tank was always under the passenger seat in(or under) the 40's.
skokem said:
I did too, but there is a guy here in town that has a '67 that has the filler on the driver side rear below the tail lights. .
below the tail lights? are they not on the frame/bumper?
He has them mounted up higher, halfway between bottom and top of tub. the filler is in the lower third of the tub by the rear door.
Over here in Germany the Location of the Fueltank changed 1979, when the newer Floorpan/tub was used.
In the old floorpan the Fueltank was inside the rig below the co-driver seat.
Newer Floorpan keeps it outside.
Funny enough the first 40´s that was officially sold in 1977 had drumbrakes all around and no smog stuff on it. They changed to diskbrakes in the front in 1979 when they had the new floorpan/tub.
is there a tank from some other vehicle that fits nicely under the rear floor, with a fill neck facing the passenger side? if not, i'm going to try making my own custom tank, but was just checking.
milesstarkey downey off road make a aux tank that mounts under the tub. all you have to do is a ss a sending unit for the fuel guage to make it a primary tank. i have one of these on my fj. when i do my frame off i plan to remove the stock tank and just use the rear tank.
there are other companies that sell the same tank you will have to look around to find one that fits your price range.
My 78 FJ45 has the tank under the passenger seat and my BJ40 has the tank under the the rear cargo area.
my '77 has the gas tank sitting right under the passenger seat inside the cab. Jeep CJ7 gas tanks go under the rear of the tub and the filler is in the rear passenger corner, but I don't know if their dimensions would allow an install in an FJ40.
so, could I get a 79+ tank and put it back there? I really don't want to spend 700 on an aux. tank and make it the main tank,,, wife has coined the passenger side the "seat of fire" and she won't go anywhere with me in it ( which really isn't that bad) until I move the tank out of the cab...
With a lifted rig it's probably not much safer in the rear.
VTFJ40- you can go ahead and explain it to my wife. i tried to explain that even a bunch of engineers said that is the best place for it, otherwise they wouln't have put it there.
If I put it back there, i would cover it with a skid plate anyway.
This is one of the reasons why I now have a 79. My fiance wasn't too keen on the underseat fuel tank either. Now matter how you look at it though, a 40 isn't exactly going to be a real safe vehicle in a severe accident. You could tell her this though. I used to have a 76 many moons ago. It rolled several times (probably 20 or 30) down a ski mountain and didn't leak any fuel. Nobody was in it, and the stock cage actually held up surprisingly well.
