Does anyone know who is delling the hardware kit and gas shocks to replace the hood springs in an Fj60
Yes, but.... the placement of the struts is totally different. The kit above is way more expensive, but the struts are 100% out of the way. All of the DIY jobs I've seen the struts are in the way, almost in the same exact spot as the assist springs.dude you can diy this whole thing for like $20. just use some rivnuts in your hood and use one of the bolt holes for the hinge spring. the gas struts are CHEAP on amazon
With the cheaper option I just removed my assist springs completely as they’re not meeded anymore and cleans it up a bit in thereYes, but.... the placement of the struts is totally different. The kit above is way more expensive, but the struts are 100% out of the way. All of the DIY jobs I've seen the struts are in the way, almost in the same exact spot as the assist springs.
Both good options, but the two deserve some explanation since the final product is different.
On the other side that strut is perfectly in the way of adjusting the idle speed screw on the carb, just like the assist spring ... for those of us still running a 2F that is haha. The more expensive kit setup doesn't have that issue since the bottom of the strut is located on the firewall. It's definitely a MUCH cheaper route though. All I was saying was "horses for courses".With the cheaper option I just removed my assist springs completely as they’re not meeded anymore and cleans it up a bit in there
