Does anyone know who is selling the hardware kit and gas shocks to replace the hood springs in an Fj60
I have this setup and wish I didn’t. Go the DIY route @MANUCHAO posted
I admittedly have zero experience with the product, I just remember him posting about it in his build thread.I have this setup and wish I didn’t. Go the DIY route @MANUCHAO posted
No worries. It is easy to install and does work. I think the struts will work better mounted to the fenders vs the firewallI admittedly have zero experience with the product, I just remember him posting about it in his build thread.
I agree. Have you noticed some flexing on the firewall. It could cause a fatigue tear in the metal. I need to change it.No worries. It is easy to install and does work. I think the struts will work better mounted to the fenders vs the firewall
Hi Manu:Okay first of all, a parts list:
2 gas shock struts, either 100 lb or 110lb (P/N 9416K16) from McMaster-Carr
4 female shock strut fittings (P/N 9424K23) from McMaster-Carr
4 male shock strut mounts (P/N 9512K98) from McMaster-Carr
4 5/16 ID / 5/8 OD steel washers
4 5/16 ID / 1.75" OD steel washers
4 5/16-18 UNC nylock nuts (I used nylock because it'll keep the nut in place while the threadlocker cures)
2 5/16 ID / 1/2 OD washers, just under 1/8" thick
Blue thread locker
You'll also need a bench grinder, drill and a 5/16" HSS bit...
- Spook50
- Forum: 60-Series Wagons
Do you happen to have a pic of the cylinders installed that you could send
