I noticed a gas puddle under the engine area yesterday, so I got to searching and see that fuel is dripping from the bottom hose attached to the charcoal canister. Since it just hangs there, I figure it is a drain hose of sorts, but my guess is only if something else in the system fails.
I got to thinking the cas cap vent might be plugged, so I go to take it off and was surprised at how much pressure was in the tank. It hissed for a full 3 seconds letting off pressure. It was 85° F inside my garage at the time. I figure with only 4 gallons of gas inside the tank, it could build up pressure, but should fuel be pushed out of the canister drain? I don't believe i have ever seen this happen before.
The vent on the gas cap allows air to enter the tank, but not leave. Is this normal? Seems backwards to me. I thought tanks were meant to hold a vacuum so vapors don't get expelled into the atmosphere. Perhaps I have the wrong cap installed?
