A little over a year ago I resorted to some older threads about CEL codes 21, 26, and 28 for my '94 80 series. Gained knowledge on those codes and I spoke to a few folks and came to the conclusion I needed new O2 sensors which I put in. Codes cleared and truck ran without issue. As of 3 days ago the same codes came back with the same side effects as before (rough idle, terrible mpg, sluggish acceleration which all slightly become less noticeable the more warmed up the vehicle gets but are still prevalent). I jumped under the truck today with time to tinker and did the following:
Disconnected both O2 sensors and inspected both male and female ends (Note: I did not unbolt and remove the sensors entirely, just disconnected the wiring plugin/harness). Driver side sensor appeared perfectly fine with no debris or corrosion on the male and female ends. Passenger side plugin had a bit of debris/corrosion on 2 of the prongs which I cleaned as best I could before reconnecting. I turned on the vehicle and codes still appeared and vehicle ran with above mentioned side effects. Turned vehicle off.
I then disconnected the battery for about a minute or two and then reconnected the battery. I turned the vehicle back on and the CEL continuously flashed but all the side effects went away and the truck ran perfectly fine. I drove it around the block a couple times and the CEL continued to flash but the truck ran perfectly fine. Excellent idle and great acceleration. TBD on mpg.
I guess my question/concern/reassurance would be if my vehicle is running as it should with no issue (CEL still flashing), should I just continue to drive it per usual and keep an eye out for side effects creeping back. Or do any of you with more experience have recommendations for me before I start driving it as normal again?
It's been a pleasure to learn and perform my own maintenance so very appreciative of any advice/tips/recommendations!!!
