I have a 1996 FZJ80 that will not start. Here's what happened leading up to it:
Had driven several miles just fine prior to going up a steep & rough incline (during a SAR mission of course), lost power, lurched a bit, engine stopped. At the exact same time, I smelled the distinct odor of burnt electronics in the cab. After this, starter cranks just fine, but the engine will not fire up.
Thought there might be an issue with fuel pump, fuel pump relay, etc. However spraying starter fluid directly into the intake doesn't make a difference when cranking.
A cursory check for spark at the distributor revealed there was none. I've spent the last couple of hours poring over numerous posts about this topic. Here's my plan of attack for tomorrow, but I'm definitely looking for any/all suggestions:
1)Check Ignition/EFI fuses.
2)Follow the FSM Ignition spark test?
3) Fusible Link (was bad, replacing fixed problem)
4)CEL with key on? NO!
5)EFI Relay?
I'll post more information as I run through these. Any other suggestions welcome!
Thanks!
1)
2)
4)
5)
Thanks!
They are just wire, if you carry basic wiring stuff, easily spliced to get you home. Don 't recall ever changing one on the trail, have always spliced/tied it back together, then done a proper repair at home.
