Fzj80 braking vibrations
So im new to the forum ...so im in need of help................
When im braking i get serious vibration up front all most like my wheels are hoping off the ground it seems its rather hard to explain the dash shake ........well everything does really......but im curious to know what it could be?
I recently bought new rotors and pads dba and ceramic brake pads up front and it stops on a dime.......yet im still getting that horrible vibrations
does anyone know anything i should look at to fix this problem?
All info is appreciated
Well more often than not that is a common sign of warped rotors. But I see you recently replaced them.
Have you pulled things apart to investigate?
Also a search may yield additional incite.
Check that the bolts that hold the calipers to the knuckle are tightened and fit properly.
I had a bolt that was striped and cause severe vibrations.
Have you replaced the rear rotors as well? They have been known to cause side-to-side shaking and steering wheel vibrations if they warp.
Something is loose in that front end...:hhmm:
Could also be a poorly balanced tire. I've had that happen before.
Lots and lots of things to check. Some good suggestions in this thread.
One big thing is the pistons maybe sticking on your calipers. This will also give you the sensation of a warped rotor. If only one piston is pushing on one side of the caliper against 2 on the other side, the rotor does not like this so much. '
Did the pads have uneven wear from side to side or top to bottom? If so then calipers are not functioning properly.
I usually do not see the calipers last much longer than 140-150 k miles with out the calipers being rebuilt. This is a few hours of time and a $50 kit from toyota and some new fluid.
This also couple with setting the bearing too loose will give you even bigger sensation of warped rotors. Good luck
Mine does the same too, it only does it sometimes and not all the time, when coming to a stop. The steering wheel will sometime shake violently. Could it be that the steering dampner is worn out and need replacement.
BTW, I checked the brake pads and they are wearing out evenly.
Probably loose bearings and/or worn birfs. Mine did the same until I had the front end rebuilt and new rotors installed.
FYI, the brake pistons should last a long time if you flush the brakes regularly. I renew my brake fluid every two years or so, and my truck has 225,xxx miles with the original brake pistons and master cylinder. Brakes work great too.
Good maintenance pays!:cheers:
Ned
I would check the bearing preload on the front hubs.
